Changing poses in aniblocks
Is it possible to change a pose within an aniblock so that it flows with the rest of the animation or do I need to reposition the pose with every frame thereafter?
  • crosswindcrosswind Posts: 9,737
    Dbl-click the block to switch to Keyframe Mode and modify the pose.
  • Yes, I understand that, but is there a way to change it so the rest of the keyframes follow through? Or do I need to do it with every other keyframes after that?
    There's no interpolation type but a Graph editor.... a bit cumbersome. You may bake the block to timeline then send back to block after tweaking.
  • DartanbeckDartanbeck Posts: 21,988
    Well, when you enter into Key Frame mode and make a change, that change will hold through the rest of that aniBlock unless you release the change by pressing the Zero key.
    I use a different approach:
    https://www.daz3d.com/the-complete-guide-to-animating-dynamic-characters-in-daz-studio
    Wanna use aniMate 2+ to do more than just 'Add aniBlocks to your Character'?
    Check out my new thread:
    aniMate 2 - Fun Things you may not have Known
