[Released] PBRSkin Plus [Commercial]
Silas3DSilas3D Posts: 834
edited November 2023 in Daz PA Commercial Products
Love the PBRSkin shader but feel like it's missing some key features?
PBRSkin Plus is an extension of the original PBRSkin shader, adding support for the highly sought-after Emission and Cutout Opacity properties!
Also included:
  • Several emission scripts to add cool wireframe effects to Genesis 9
  • Selected surface emission scripts that can be used on any figure or prop
For the first time, you can create some truly unique Iray materials by combining standard bump/normals/displacement with detail weight, cutout opacity, and emission.
Note: The original PBRSkin shader (included with Default Resources for DAZ Studio 4.20+) will also need to be installed.
Purchase here: www.daz3d.com/pbr-skin-plus
Post edited by Silas3D on
  • What happens to SSS when Cutout Opacity is used?
  • Silas3DSilas3D Posts: 834
    Hi Richard, as with Iray Uber it disables it if an opacity map is used - unless Iray is updated with support in the future. But it can be used uninhibited where SSS isn't needed, such as fabric that can benefit from the extra detail channels.
    Thanks, I thought that would be the case but thought it wise to have it explicitly stated to avoid confusion.
  • This is great, guys! Thanks so much for this!
    Pleasure! Hopefully will be useful in your own products :)
  • SotoSoto Posts: 1,451
    Please do a merchant resource version :D
    Hi Hellboy! We've decided not to do this at the present time - you're welcome to use (but not distribute) the shader in your products and then list it as a required product on store page.
