3d Universe's Sandy Bay Seaside Village
RiggswolfeRiggswolfe Posts: 916
edited October 2023 in The Commons
Do you think [3d Universe's Sandy Bay Seaside Village] this model would work in a modern version of Daz? It looks like it is probably from the Daz 3 days or maybe even Daz 2. It has a mix of pp2 and Daz files. I know you'd probably want to replace textures with modern shaders but I'm still curious if it would work at all without perhaps needing some work like converting the file types or something.
  • SapphireBlueSapphireBlue Posts: 1,417
    edited October 2023
    Riggswolfe said:
    Do you think this model would work in a modern version of Daz? It looks like it is probably from the Daz 3 days or maybe even Daz 2. It has a mix of pp2 and Daz files. I know you'd probably want to replace textures with modern shaders but I'm still curious if it would work at all without perhaps needing some work like converting the file types or something.
    I got this recently and thought I might as well try it out after reading your question and see how it looks. It comes with a pp2 file for the full scene for DAZ Studio specifically. I just did a very quick try and it works just fine I think, but for Iray, you first have to get rid of the Environment Sphere in the Lighting group in the Scene (first screenshot) otherwise the whole thing just renders black. I just used Sun-Sky and it seemed just fine! (Second screenshot shows Iray Preview with Sun-Sky lighting, after deleting the Environment Sphere. I also switched off the other Lighting stuff, but that was just for testing.) I also tried a regular day time HDRI and it looked great too.
    It looks very nice. Since it's a toon set, I personally wouldn't even bother changing textures unless something seems really off. I might try out some test renders soon. Hope this helped!
    Post edited by SapphireBlue on
    It looks quite nice. For some reason I was under the impression PP2 files don't load into Daz anymore so I wasn't sure it'd actually load into a current version of Daz Studio at all. Changing the textures with architecture shaders or just converting the existing ones to Iray Uber would probably work and had occured to me. As had getting rid of the sky dome and any Poser lights it uses. I'd probably replace the Sky Dome with an HDRI.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,514
    the scaling is terrible though for populating it with carts/cars etc
    toony people you may be able to
  • RAMWolffRAMWolff Posts: 10,382
    So the one that's got the glow around it contains all the packs that are to it's right?
    1001 x 459 - 410K
  • NorthOf45NorthOf45 Posts: 5,896
    Yes, everything in those packs, and then some, like the grounds, cameras and skydome, and a couple more props, like the lighthouse and the watertower.
  • LeanaLeana Posts: 13,504
    edited October 2023
    pp2 and other poser files definitely still work in recent versions of DS (with the same limitations as before).
    Post edited by Leana on
    I have the bundle, surprise! it's by 3DU, and it works fine.
  • For a scene set like this one that's smaller in scale than normal Daz characters and props, an easy fix would be to make a new Group in the Scene tab, lasso everythng that constitutes the scene, drag that into the Group (making sure you have things set to parent-in-place), then simply resize the Group upwards so that it matches the scale of the regular Daz characters.
    still cannot put even toon cars in it because the scale of the roads and bridges are totally out of whack
    as a pedestrian and maybe bicycle town it could work
  • nomad-ads_8ecd56922enomad-ads_8ecd56922e Posts: 2,018
    edited October 2023
    Actually, it was another merchant I was thinking of when I said that thingy about the toon scene being smaller scale than normal, so I'm not sure if we were talking about the same thing when you said the scale was out of wack.  I had bought 3DJoji's BeachCorner, and when I rezzed the set and placed some more recent cartoon characters in it, I discovered that that entire beach scene was at something like 50% scale or 60% scale or something off the wall like that.  It's like they were standing around in a scale model of a beach resort!  laugh
    edit: Okay, I see what you mean now.  Looking at the building next to that little road with the trafffic-stripes, I notice that, judging by the size of the door in the building, the road looks like it's expecting kids peddle-cars instead of motor-vehicles, and I'm not even sure if the peddle-cars would fit on it..
    Post edited by nomad-ads_8ecd56922e on
    The older products are influenced by the lack of (real) standard scale in Poser
  • ArtiniArtini Posts: 10,902
    edited October 2023
    yes
    videos I did
    edited October 2023
    Nice videos, Wendy.
    You got even waterfall and water moving.
    By the way, I have stopped using Automatic 1111 and started with ComfyUI.
    Works much better with XL and my Nvidia graphics card with 8 GB of VRAM.
    Finally can create much bigger images (even more than 1920*1200).
    Post edited by Artini on
    edited October 2023
    Artini said:
    Nice videos, Wendy.
    I like A1111 but it stopped working on my PC
    my AMD iGPU is apparently the issue, it won't see my Nvidia CUDA
    am beyond frustrated so creating weird insert mesh curve brushes in Zbrush instead and keep crashing it devil
    is this a highjack or a derail?
    Yeah I think it isdevil
