• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Exporting cameras to blender
rhees.birmanrhees.birman Posts: 18
October 2023 in Blender Discussion
Has anyone managed to reliably export daz cameras to blender? The only way I can see to do it is to use .fbx which sort of works, but the focal length or sensor size is wrong. For example, a daz camera with 120mm focal length and 36mm frame width at 1800x1200; I exported it to .fbx and then imported that into blender, which gave me a camera with the correct position/orientation and correct focal length value, but the sensor width came in as 20.7264mm and the lineup is wrong. If I set the sensor width to 36mm to match the daz setting, the lineup is still wrong. However, if I then set the focal length to 80mm the scene lines up perfectly. Am I missing something here? Or is there a bug in the daz .fbx exporter? Or is the focal length in daz just completely wrong? I've tried with different .fbx versions and different blender versions and still have this issue.
  • rhees.birmanrhees.birman Posts: 18
    October 2023
    Alternatively, in the above example, a blender setting of 120mm focal length and sensor width of 54mm also gives the correct lineup.
  • PadonePadone Posts: 4,326
    October 2023
    diffeomorphic can correcty import daz cameras
  • crosswindcrosswind Posts: 10,276
    October 2023
    DDI ~
    October 2023 edited October 2023
    Thanks, I tried installing diffeomorphic but it doesn't work at all for me in blender. I just get a blank UI, and a missing "DAZ Importer" tab. I tried v1.7.0 and v1.7.1 and blender v2.93 and v3.3 and get the same issue. I'm sure I've done something wrong, but the diffeomorphic install documentation seems very out of date and the website is extremely disorienting to navigate. I don't see any issue tracker on the bitbucker so I have no idea how to proceed. Any suggestions?
    395 x 373 - 76K
    Post edited by rhees.birman on October 2023
    October 2023
    Get latest ver. from here - https://bitbucket.org/Diffeomorphic/import_daz/downloads/
    Install and activate the add-on in Blender. Remember to copy 'to_daz_studio' - Scripts folder from ZIP file to your Daz Library.
    1160 x 744 - 86K
    2560 x 1400 - 692K
    Yes, it's already installed and activated, but there is only one tab showing, and it's empty. The installation instructions say to install the blender plugin from the .zip file, but the .zip file contains all three components (blender plugin, daz plugin, and MHX runtime) as unzipped folders. I improvised by zipping up just the blender plugin and installing from that, which resulted in the broken plugin as shown in the attached image above. I don't know what I am missing.
    -- EDIT: Never mind, I got it to work by just unzipping the whole thing into the AppData\Roaming\Blender Foundation\Blender\3.3\scripts\addons folder.
    November 2023
    If it's helpful to others, I found the key piece of information in the diffeomorphic code. To have your .fbx camera lined up correctly in Blender, you need to make sure you have:
    * The same render dimensions as the DAZ scene.
    * The same focal length.
    * "Sensor Fit" must be set to "Vertical" and the sensor "Height" set to the same value as "Frame Width" in the DAZ scene.
    1431 x 861 - 488K
    1640 x 807 - 430K
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
