Problem to manually change the pose of a character.(Solved)
GREG49GREG49 Posts: 0
edited August 2012 in Daz Studio Discussion
Since installing DAZ 4.5, I have a small problem.
I can no longer move the members of Genesis with the mouse.
I click the menu Pose and Animate, and then click Editor. Then I click on my character, but I can not select his arm and move the mouse.
The whole body of the character is selected. Unable to select a body part.
It seems that the character is locked.
Someone to help me?
thank you
  • Richard HaseltineRichard Haseltine Posts: 111,268
    Try clicking on a body part - does the control widget jump to its origin?
    I don't think you have the Translate tool selected, it looks more like the Surface Selection. Go to tools, and select Translate or use the shortcut, Alt+Shift+T.
  • GREG49GREG49 Posts: 0
    edited August 2012
    I closed and restarted DS4.
    I clicked on the head (with the tool Translate).
    Impossible to move the head with the mouse.
    1440 x 810 - 461K
    1440 x 810 - 510K
    Post edited by GREG49 on
    Click a second time - the default behaviour, which you can change in Tool Settings, is to select the figure first and then the bone. You can also adjust Selection Highlighting so it doesn't flash an overlay across the mesh, if you want.
    Ok thank you very much for the help.
    It was selected Node in Node Selection Mode.
    Before, I was Root Node Only
    Thank you very much.
    1990 x 1119 - 731K
  • Jim_1831252Jim_1831252 Posts: 728
    Thanks Richard. This "problem" just popped up about half hour ago (no idea why). I tried the usual: restart Studio > restart computer > look at selection tools > become very confused > google (forum search doesn't work :( ).
