• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic import - texture/material issues?
TurnerTurner Posts: 116
October 2023 edited October 2023 in Blender Discussion
First, thanks for the awesome plugin.
Just started using it, and on import I seem to be missing some textures/materials/channels, or perhaps something isn't set up correctly?
In this image, the bangs (kin hair) card (I assume) is throwing a solid shadow, and the skin material is missing. I assume the kin hair itself is causing the shadow issue.
Also, can we adjust the eyes to be less bloodshot & "glassy"? (I think the eyes may have to do with some subsurface setting, but not sure.)
Any suggestions?
Post edited by Turner on October 2023
  • Singular3DSingular3D Posts: 608
    October 2023
    Which version of Blender do you use? Which version of Diffeomorphic? Did you adjust the path for Daz in the Blender Diffeo Settings? Did you use Easy Import?
    In the shading tab of Blender, you can see, if the textures are assigned correctly.
    This is probably just a minor issue andmaybe caused by some missing settings.
  • TurnerTurner Posts: 116
    Hmmm...
    Thanks for the note -
    Blender is 3.4.1, importer is 1.7.1.
    All paths were set up (this morning, in fact) according to the instructions.
    Obviously, here, Blender thinks "fingernails" is the right material.
    Also, most don't have any texture assigned to them.
  • PadonePadone Posts: 4,019
    October 2023
    Obviously, here, "fingernails" is just one of the materials assigned to the selected mesh. If blender can't find the textures it means you didn't assign the daz studio folders in the global settings, be sure the names are the same in daz studio ad blender.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Install/Setting up the DAZ root paths
  • crosswindcrosswind Posts: 9,580
    October 2023
    Which character did you use ? That seems like the Base figure.
    This is a default result of a character based export / import via DDI. There should be no issue with 3.41 and 1.7.1 as I've been using these settings from 3.0 / 1.6.
    1927 x 1395 - 999K
    Yes - sorry, meant to say it thinks it's missing (fingernails).
    When I hit "Load Rooth Paths" the window closes - I assumed it knew where the location of my .json file was based on exporting it using "Save Paths". (Also, since other materials were showing up.)  I tried exporting it to another location but it didn't update, so I assume a restart is in order.
    YES!! Restart... I was able to select my .json file. Thanks for your help. The hair is still not rendering correctly, but I think that's a separate issue.
    October 2023
    Hi Crosswind - yes, this is the Genesis 9 base with kin hair.
    What do you mean by this being a "default" result? (As you see above, restarting my PC - rather than just Blender - allowed me to pick the .json file (maybe a conflict with another addon?), though some materials appeared without doing so, and the hair still doesn't render correctly in Cycles.
    October 2023
    Diffeomorphic will warn you if the render settings are not enough for a usual daz scene, and there's the option in the global settings to let the addon "upgrade" the render settings for you. Nevertheless for transmapped hair it is usually the transparent bouncings, you may need 64 or more depending on the hair complexity. Or you can use the full global illumination preset for the best quality.
    render properties > light paths > max bounces
    Thanks Padone - I enabled warnings, but didn't get any.
    I tried setting it up with full GI & bounces set to 64, but no luck. May dig around in nodes a bit.
    October 2023
    Hi, Turner. Sorry, I meant with default Global Settings but setting up the corract Daz Libs path(s) is still the prerequisite, as you've done it correctly.
    As for the hair render issue, I'm not sure as I don't have that hair but more likely it seems a geometry or shader issue. You may check and tweak first.
    October 2023
    then try 128, if the hair is very complex 64 may not be enough
    October 2023
    I tried OOT's much complex hair with nearly 1Mil polygons and more surfaces, there's no such an issue even with very low settings in Light path.
    This kin hair seems just a mesh hair.. weird. If there's a separate surface or vertex group on that 'black bang', you may hide it, and may check if it uses the same shader setup as other slots.
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,238
    October 2023
    The total bounces is still set to 32.
    October 2023
    The transparent bounces are independent from the total, that is, we can have 16 total and 128 transparent for example.
    https://docs.blender.org/manual/en/latest/render/cycles/render_settings/light_paths.html
    October 2023
    Well, Cycles is not like Iray.... high bounces value there will result in very slow rendering....
    And I really don't think these settings can resolve OP's issue...
    October 2023
    It is also possible to use a "probabilistic termination" for transparency and bounces in general, I never used it so don't know how good it is.
    render > sampling > advanced > min bounces
    Light paths are terminated probabilistically when specifying a minimum number of light bounces lower than the maximum. In that case, paths longer than minimum will be randomly stopped when they are expected to contribute less light to the image. This will still converge to the same image, but renders faster while possibly being noisier.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
