The Free AutoFit Lesson zip file
inquireinquire Posts: 2,465
When I unzip the Auto Lesson zip file, it has an installer. What does it want to install, and where? Is it just something to read? Could I place it anywhere and then delete it later?
  • fixmypcmikefixmypcmike Posts: 19,743
    They are interactive lessons, they install to your DAZ Studio application folder and you launch them from the strip in the lower right of the application window.
  • inquireinquire Posts: 2,465
    OK, I installed it, but when I try to run it, I get a notice that two files are missing. Is there someplace where I can just read about the auto fit tool?
    There is some information here: https://www.youtube.com/watch?v=lVINND4L5tA#t=76
    You should be able to install and run these lessons inside DS. I have never had any problems with installing or using them, and I use DIM to install them.
