Iron Man armor problem.
redips28redips28 Posts: 10
Hi Guys,
I download this model :
http://inlitestudio.com/3d/product/ironman-suit/
I try to pose it, but it don't work.
When I move something, only "parts" are moving, not a whole "armor/body".
I do something wrong?
Thanks for help.
  • fixmypcmikefixmypcmike Posts: 19,705
    Are you moving with the Active Pose tool?
  • HorusRaHorusRa Posts: 1,665
    edited March 2019
    Post edited by HorusRa on
  • redips28redips28 Posts: 10
    Yes, I try to use Active Pose tool and nothing is moving.
  • R25SR25S Posts: 595
    edited June 2015
    Make sure you select the nodes marked with a tringle (in the Scene tab) not the ones marked with a cube. If you select the ones with the cube you only move the armour parts. If you select the ones marked with a triangle you move the whole body part.
    You also can select the one with the three cubes (at the top of the Scene) wich select the whole figure and than select a pre-made pose from your Content.
    1920 x 1080 - 253K
    Post edited by R25S on
