• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
mcjTeleBlender:Daz Studio scenes/animations w/Blender's Cycles Engine
«1…27282930313233…49»
  • mCasualmCasual Posts: 4,607
    May 2015 edited May 2015
    i'll try to show step by step how FesliyanStudios does shadows in Cycles
    https://www.youtube.com/watch?v=Ke7plNnwYl0
    Fig 1
    1 - create a plane, large enough to catch the figure's shadows. i applied the default diffuse BSDF material to it (matte)
    2 - place a sun-light , the sun "size" can be reduced to produce sharper shadows, here 0.04. Intensity 1
    3 - select the plane by right-clicking on it
    Fig 2
    4 - type M, this is the shortcut for the "Move to Layer" command,
    5 - i click on the 2nd square to Move the Plane to Layer 2
    6 - i Shift-Click the 2nd square of the "Visible Layers" selector to make Layer 2's content visible
    Fig 3
    7 - Go in the Render Layers Tab
    8 - Use the + button to add a Render layer, rename it to "ShadowPlane", rename the first Layer "Amy"
    9 - Associate Amy with render layer 1 by clicking on "Amy", then on the first "Layers" square
    10 - Associate ShadowPlane with render layer 2 by clicking on "ShadowPlane", then on the second "Layers" square
    Fig 4a
    11 - Select the ShadowPlane layer, Expand the "Passes" panel, check the "Shadows passes
    Fig 4b
    12 - Change one of Blender's views into a Node Editor view
    13 - Select the "Layers Editor" type of Editor
    14 - Turn on the "Use Nodes" option
    Fig 4c
    15 - Add a second Render Layer node using the Add/Input/Render Layer menu
    Fig 5
    16 - We should 've done it earlier but it's still time, go in the Renderer settings panel and turn on the Film/Transparent option
    17 - render your scene ( you can lower the sampling values to get a rough idea. Notice how the renderer does 2 passes
    18 - using the Add menus, add a Color/Mix node and change its type to "Subtract"
    19 - Connect the Shadow-Plane Layer's Alpha and Shadow outputs to the Image inputs of the Subtract node
    20 - Using the Add menus, add a Converter/Set Alpha node
    21 - change the set Alpha node color to Black
    22 - Connect the Image output of the subtract node to the Alpha input of the Set-Alpha node
    23 - Using the Add menus, add a Color/Alpha-Over node
    24 - connect the Image output of the Set-Alpha node to the first Image input of the Alpha-Over node
    24 - connect the Image output of the Amy Render Layer node to the second Image input of the Alpha-Over node
    25 - connect the Image output of the Alpha-Over node to the Image Input of the Composite node
    1172 x 544 - 269K
    1280 x 720 - 342K
    960 x 540 - 158K
    960 x 540 - 137K
    1246 x 862 - 342K
    Post edited by mCasual on May 2015
    Fig 1
    this png image has an alpha layer, ideal for compositing
    Fig2
    in PaintShop i did a "Selection from alpha channel"
    and i pasted this as a layer, over my background image
    then i deleted part of the shadows that were spilling over the stone ramps
    Someday someday, i'll have a script that performs all that in 1/100th of a second
    Fig 3 ... why not rty ... wall shadows !
    Fig4 Tada ! ... doing the final composition was easier in PaintShop , notably, coloring the shadows
    1920 x 1080 - 1M
    782 x 452 - 138K
    784 x 452 - 164K
    960 x 540 - 145K
    960 x 540 - 101K
  • yajoojmajoojyajoojmajooj Posts: 24
    May 2015 edited December 1969
    Okay, so now I know how to get the shadows to work but where can I find good background plates that would match with my models. I mean Victoria 4 and Genesis 2 Female.
    I'm not going to try with an HDRi background because you said it yourself that it won't make a good background plate. Any keywords I can search on Google Images or..? Deviantart? Free websites?
    Thanks in advance. :)
    in the previous forum page i was saying
    usually here http://www.hdrlabs.com/sibl/archive.html
    but there’s others on deviantart, quite huge though
    google keywords : hdr equirectangular spherical environment
    http://zbyg.deviantart.com/art/HDRi-Pack-3-112847728
    you could also do the ground shadows in Daz Studio and composite them with the Blender Render
    https://www.youtube.com/watch?v=qo2OVy9tf8E
    an august 2014 video about ground shadows in blender cycles
    Okay! Thanks a ton mate!
    Sorry for bothering you again Casual, but can't it be possible to composite the HDRi background with the model and shadow in Blender Cycles? I mean look like she's standing there? I know you showed the method with using another program but not Blender Cycles.
    The first image shows how it's turning out when an HDRi is applied and your method of shadow catching is used.
    The second image is the PNG which is turning out to be perfectly okay. I mean complete transparency.
    So I hope you understand my question.
    Peace.
    719 x 717 - 226K
    1414 x 812 - 226K
    Post edited by yajoojmajooj on May 2015
  • DM3DDM3D Posts: 133
    June 2015 edited December 1969
    Casual,
    I know you mentioned that you might attack the materials issue (specifically the glossy) situation when exporting materials using mcjTeleblender 3.0. I wanted to let you know that I am using the newest, test version of Blender's anticipated 2.75 release. With this, and actually the last few releases, I am finding almost all materials, (hair, clothes, shoes, etc.) to be exported with incredibly high gloss.
    I can't even seem to control the gloss mix to the extent I need to with the export settings. I am currently at a gloss factor of .01 (not even sure if the script allows that) and a roughness factor of .5. I wonder if when you revise the script, you can make it allow whatever gloss factor is actually entered in the script control box? There may be other fixes that you know of but that one seems to be a biggy. I can almost always correct the situation by going into the diffuse/gloss mix node setting and lowering the gloss influence value.
    IRAY in DAZ looks very powerful but I just can't fathom giving up the node versatility and the user interface of Blender. It is so much more powerful. Maybe DAZ will keep making strides forward to allow some of the robust functionality that Blender provides while still maintaining a non-intimidating user interface for novices.
    I NEED mcjTeleblender!!! ;-}
    June 2015 edited June 2015
    Peace.
    I dont have a lot of experience using the Blender compositing nodes
    and using a paint program like Paintshop had the advantage that i could easily colorize the shadows and lighten them
    what i did is,
    i turned rendering Off for the figure and shadow-catching plane,
    i turned Film/Transparency Off
    Not having moved the camera, i rendered this
    So i obtained a render o f the background from the same point of view as was used to create the Figure+shadow image
    In paintshop i loaded the background, loaded the figure+shadow PNG image
    used Paintshop's "Select/Alpha"
    this selected the figure and shadow only
    Copy
    and i Pasted it over the background as an image
    Then i selected only the shadow areas
    and lightened it and colorized it, a bit of yellow
    If you search youtube for "Blender Cycles Shadow" you will find examples where they do this compositing task - Chroma-Key/Green screen video tutorials also inevitably do this step
    718 x 718 - 251K
    1920 x 1080 - 1M
    Post edited by mCasual on June 2015
    DM3D said:
    Casual,
    it's always important to set the Specular Color of the surfaces in Daz Studio's surfaces Tab darker than the defaults
    there's an issue i want to fix also, the default Glossy type in Blender is now GSX or a name like that, and it was Beckman previously
    in my tests it didnt make much difference
    if i recall correctly, the Gloss Factor and Roughness factors, are used mostly by the Teleblender-2-compatibility mode
    and/or when you are dealing with a some shaders. So when working with teleblender3 mode, the Daz-Studio-Surfaces-Tab settings for Glossiness and Specular strength and Specular color must be carefully set ... because they will be applied in Blender's node trees
    i tend to avoid teleblender's Gloss Mix node, i'm old school ya know, i was raised on the Gloss-Add nodes :)
    the other important tip is to convert the complex shaders used by figures like Genesis into standard DazDefault shaders
    because it helps TeleBlender find the surface properties, and because the obj/mtl exported file is more complete when using DazDefault shaders
    Casual said:
    DM3D said:
    Casual,
    Thanks for your quick response Casual. It seems like almost every material I deal with has this gloss issue. The materials are set up perfectly in DAZ but when exported, the introduced values seem to throw everything off. This is happening with the majority of materials I export using TB 3.0.
    I'll try to do a test export with a garment or hair mesh and will provide specific screen caps on the export parameters and the resulting node setups with sample renders. Then I'll tweak the node values (not changing the node configuration) and show the resulting render. Maybe that will help as you consider any changes you may wish to introduce. You really do have a great product and for us Blender users, it is unique and unmatched.
    Alright, thanks man!
    Huge props. And considering I'm doing Blender Cycles for a while and I couldn't come up with this trick really explains how bad I am with these.
    You're the man!
    Finally got it to work. Not my best one though.
    2000 x 2000 - 1M
    Post edited by yajoojmajooj on June 2015
  • jakzun_9ecf4a7248jakzun_9ecf4a7248 Posts: 25
    hi,
    i just got mcjGeoSender and i don't know where to put it or how to open it in daz - help?
    jaypowers said:
    hi,
    note that mcjGeoSender's purpose is not exactly like mcjTeleblender, and not truly related to Blender
    what it does is, it helps you export a series of animation frames as OBJ files
    and fix a few issues that were preventing Blender from loading them
    It's old, so i dont know if it works with DS 4.5, 4.7, 4.8
    using mcjTeleblender you could produce the same series of OBJ scene files
    mcjTeleBlender has been updated more often and works well with new versions of daz Studio 4.5 and up
    if mcjGeoSender is not compatible with the new DS4.7+ then i'll update it on my site today
    But to answer your question specifically
    mcjGeoSenderScriptsFeb18th2012.zip
    should be unzipped in a Daz Studio Content/Scripts folder
    mine are in C:\Program Files (x86)\DAZ\Studio\content\Scripts\mcasual
    nowadays people install it in places like
    C:\Users\YOURUSERNAME\Documents\DAZ 3D\Studio\My Library\Scripts\mcasual
    once installed there
    you can find them in your Daz Studio Tab under
    Daz Studio Formats / Studio \ Scripts \ mcasual
    or
    Daz Studio Formats / My Library \ Scripts \ mcasual
    Good News ( good news for me too )
    mcjGeoSender works with the latest versions of Daz Studio 4
    in the image below, i animated a cube over 30 frames
    used mcjGeoSender to export the 30 frames as 30 onj files
    then i imported the 30 obj files back in Daz Studio
    ( since blender has a different system of axis the cirle of cubes is vertical instead of horizontal
    thank you - your scripts are the bomb (bows)
    i already have a tab full of your scripts, i didn't put this one in there because it had so many other files attached - i wasn't sure
    i'm just exporting objs, not going to Blender
    the folder shows in the content tab but, the pane is empty - let me reload daz...
    mcjGeoSender works with the latest versions of Daz Studio 4 ( tested on DS 4.8 Public )
    used mcjGeoSender to export the 30 frames as 30 obj files
    then i imported the 30 obj files back in Daz Studio 4.8
    ( since blender has a different system of axis the circle of cubes is vertical instead of horizontal
    700 x 910 - 428K
    yeah, still not showing folder contents - i just pasted the entire folder (mcjgeosender_files) in the scripts folder - the folder shows but, it's empty
    this zip file?
    https://sites.google.com/site/mcasualsdazscripts/mcjgeosender/mcjGeoSenderScriptsFeb18th2012.zip?attredirects=0&d=1
    note it has to be in a MyLibrary/scripts folder or in a Content/Scripts folder
    not in the Daz Studio scripts folder
    also, your Daz Studio must have that Content folder in its list of Daz Studio Format content folders
    you can see that list in Daz Studio's Edit/Preferences/Content Library / Content Directory Manager panel
    635 x 557 - 66K
    Oh YaY DS 4.8 IRay has super easy to use Ground Shadows
    700 x 910 - 581K
    that's a different download, altogether - boo-ya - i works
    thank you
    it saves materials every instance - i'm trying to find a copy of geosend - it's nowhere to be found - i'd even pay for it - i need to export obj files and it took all night
    thank you
    thank you
    mcjGeoSender the script works in Daz Studio 4 without the need for the mcjGeoSender.dll plugin
    also mcjGeoSender the script works in Daz Studio 3 without the need for the mcjGeoSender.dll plugin
    but it's way slower than DS4
    so i created the mcjGeoSender.dll plugin for Daz Studio 3
    if you use Daz Studio 3 and have the mcjGeoSender.dll plugin
    you need to put that DLL file in daz studio 3's "plugin" folder
    there's a DLL for 32 bit and one for 64 bit
    on my PC i have
    mcjGeoSend_32bit.dll placed in c:\Program Files (x86)\DAZ 3D\DAZStudio3\plugins
    and
    mcjGeoSend_64bit.dll placed in c:\Program Files\DAZ 3D\DAZStudio364\plugins\
    if the plugin is installed like that
    the mcjGeoSender script will detect its presence and use it to accelerate the export process
    okay - i have 4.8 and maybe i'm missing something but, it doesn't use just one .mtl - it was saving all night and all today til i canceled it - it saved materials everytime - so, i'm just trying to get daz 4.8 to export sequenced objs and one .mtl file
    what do i have to do?
    i thought i needed that .dll
    hey, i'm overworked right now and didn't get what you said - okay - i got it - get the dll from the script - thank you
    but as i was saying, the dll is only available for Daz Studio version 3, i wont work with DS4.7
    and the one-mtl-file option is indeed only obtained when using the plugin and DS3
    i will now see if i did include the option in mcjTeleBlender .... which does let you export animation as series of obj files ...
    awh unfortunately mcjTeleBlender also requires the DS3/Plugin in order to get the one-mtl option
    what i'll do is, right now is, i'll write a script for Daz Studio 1, 2, 3, 4....
    that quickly opens your .obj files and changes the
    sentence that reads for example
    mtlfile myscene44.mtl
    with
    mtlfile myscene.mtl
    so all the obj files will now share the same mtl file
    the myscene.mtl will simply be the first mtl file typically myscene000.mtl but renamed to myscene.mtl
    okay, the 64 .dll is in the plugins folder:
    C:\Program Files\DAZ 3D\DAZStudio4\plugins
    it still creates multiple .mtl files
    i restarted it - same thing
    it's fast, tho
    it's fast, tho
    read the preceding post -
    i'm writing the script , it will be ready in a few minutes
    412 x 492 - 54K
    wow.
    let me donate to your paypal...
    jaypowers said:
    wow.
    this wont be necessary, plus i dont have a paypal, if you insist you could give me a $5 Daz Store coupin or gift certificate i'm not sure
    i think the script will play it safe, it will save the modified .obj files under the same name, but with the prefix "out"
    instead of overwriting your obj files
    so it will be your call to delete the originals or not
    i could add a "Delete button in the script itself" also
    474 x 208 - 16K
    800 x 800 - 58K
    406 x 402 - 43K
    i need your email to purchase a gift card
    thanks again
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
