Iray Preview Not Working Well
James
In the viewport, when I keep moving my camera, it shows the iray preview, but then when I stop, it becomes like smooth shaded again.
How to solve this?
Post edited by James on
Oh, did it? Did you hold your mouse button or not when stop moving the camera view ? Any screenshot, and your Draw Settings as well ?
Wether holding the mouse button or not, when stop, the iray stop.
drawing pane:
https://prnt.sc/uf4AZ9_2D8Fu
https://prnt.sc/ejb3luoaHSQA
when moving:
https://prnt.sc/3pPcr-YsWj30
when stop
https://prnt.sc/ssVG9P2FTmKe
OK... I remember you have a 40xx, right ? In Draw Settings, change Manipulation Resolution to 1/2 or 1/4, see if it's improved.
Yes. 4070ti.
has no effect.
I'm sorry I could not reproduce the issue. Have you turned on ECC on the card? Check it in your NVIDIA Control Panel...
I can't find ECC on Nvidia Control Panel.
Where is it?
Press Start key , search Nvidia Control...
I mean I know Nvidia Control, but where inside the control is the ECC option. I've googled, but the search result doesn't help.
It seems I've found the problem. There's an item if I delted it, iray preview works again.
