pJCM - Keyed TCB problem
JamesJames Posts: 1,191
edited September 2023 in Daz Studio Discussion
GF8
I'm making a pJCM morph to fix the shape of a butt.
When the L thigh rotate the buttmorph kicks in.
I used Keyed TCB.
The value is as follow
-100:1
-60:0.1
-59:0
0:0
But the value of the butt morph just stay at 100% no matter the L thigh rotation value.
The value of L thigh rotation is the 1st stage controller of the butt morph.
Note: I'm not replacing any existing pJCM. I make my own.
Post edited by James on
  • crosswindcrosswind Posts: 10,358
    Assuming you use Bend dial on Left Thigh Bend:
    - Drag Bend dial to this pjcm morph in Property Hierarchy
    - Set Keyed TCB, but just need to set the range as:
      Key -115:1
      Key -60:0
    (It's a normal way... no need to set 59:0, 0:0.)
  • JamesJames Posts: 1,191
    Key -115:1
      Key -60:0
    OK.
    So... I'm not sure what happened,
    I closed daz.
    Repeat my own step.
    And it works as I undestand it.
    It's like the last time.
    Reopened DAZ and it worked as it should.
    Maybe DAZ has somekind of a bug or something.
    Again? So give it more tries... if the similar problem happens with General Release, use Public Build instead.
  • lilweeplilweep Posts: 2,883
    try alt clicking the morph if this happens to reset to expected value.
    if you have manually dialled the morph, then that will override the keyed values in some way.  So need to reset them by alt-clicking, or just restart daz studio i guess, as you have done.
    Post edited by lilweep on
