Kindred Arts Interior Speed lights HELP
ChoppskiChoppski Posts: 641
edited September 2023 in The Commons
Does anyone who has [Kindred Arts Interior Speed lights] this know how to make the culling camera work? The note that comes with it says to use the culling slider, but I don't see one anywhere. ANd if I adjust any of the planes, part of the picture doesn't render. Any advice appreciated.
  • Richard HaseltineRichard Haseltine Posts: 109,474
    Please put your question in the post body and the title - Daz 3D Forums
    I would exect the slider to be on the camera, or the group that contains camera and plane. It sounds as if it is just a Section plane parented to the camera - everything on one side gets hidden, so if you move it too far forward it will start hiding stuff you can normally see.
  • I expected it to be on the camera. I THINK that by default it is just removing everything outside the camera's frame, and that's mostly what I want. But was lost as to how to adjust it.
  • mdingmding Posts: 1,763
    kindred arts also created a culling camera for https://www.daz3d.com/interior-light-pro-for-filament-and-iray
    There the culling slider is under parameters - camera or currently used. I have both, but it is wierd, i can't find a culling slider in the speed lights camera.
    Post edited by mding on
  • barbultbarbult Posts: 26,581
    I couldn't find the culling slider either. I'm pretty sure I submitted a help request about it, but haven't received a CS reply. Now the help request sign in button doesn't work (just  refreshes the same page) so I can't check my existing requests.
    You are the second person to say that, I think - I am still able to sign in, then click my name and see My Activities using Firefox. Using my @daz3d.com I can get to the same page in Edge.
    I don't mind buying the other one, but the product page doesn't list it as required. I might get the other one just to have more options.
    I'm also using Firefox. I'm on Windows 10, if that matters. Of course, my email is not @daz3d.com. I am using a Gmail address.
    Post edited by barbult on
  • I sent Kindredarts a message but haven't heard back.
    This is the URL of the page that is displayed after I click Sign In on the Help Request page: https://bugs.daz3d.com/hc/en-us/signin?return_to=https%3A%2F%2Fbugs.daz3d.com%2Fhc%2Fen-us%2Frequests%2Fnew
  • I bought the other set--it was like 4 dollars--and the culling camera in that one clearly works, even with the hdris from the new set.
    FWIW, I clicked on your link Barbult and it to took me straight to a page where I could put in a help request. Is it not doing that for you?
    It just goes back to the same page I was on, with the button to sign in.  It has an image of a lady's eyes and "How can we help" with a search bar. I'm signed into the store and forum, but I can't sign in to the help center.
    I wonder if the help center sign in problem is related to that website testing, where different people had different versions. Maybe it works for some versions, but not others.
  • That's odd. Mine went to that page, and then refreshed to the submit a ticket page. And there are two links at the top--submit a ticket and published artists help center. It's weird thought because I am not a published artist so I would think I shouldn't have access to that.
    I'm on Firefox, and the account I use there is not a Daz 3D address. Currently I have the image drop down again (after a spell with the old-style menu) and the other account had the sidebar. I can't think why it would matter, but I don't have Daz Deals installed.
    I guess I have what you refer to as the old style menus now. I tried starting firefox in Safe Mode (no extensions, etc.) I still cannot sign in to the help center. Safe mode behaves exactly like normal mode.
  • Try with a different browser, maybe?
  • DaventakiDaventaki Posts: 1,624
    I use Firefox and was able to sign in and look at my activity with no issue just now. When the new menus rolled out I started with the text menus and now have the image menus.  Maybe try to clear out your Cache and history and see if that helps?
    I tried a different computer and it worked there. When I'm back on the other one, I'll try clearing cache.
    Still, i hope and from my good impression assume kindredarts will fix this product by adding the missing culling slider.
  • ArtiniArtini Posts: 10,604
    I also have bought these 2 products, so maybe using the camera from
    will fix the problem for the time being.
