CBS/ JCMs Help
13»
  • In the Parameters pane option menu (the lined/hamburger button in the top corner, or right-click the tab) set Preferences>Consolidate Properties off - if you have botyh figures selected you will see a separate slider for each.
  • crosswindcrosswind Posts: 9,639
    edited August 2023
    Ah, I wrongly thought OP wanna have a separate pane... But in such a way,  you will find the sorting of dials change in an interesting way, when Ctrl + selecting multiple root / sub nodes one by one. I don't know why... For fixing things, I'd rather use 'traditional' way.
    Post edited by crosswind on
  • JamesJames Posts: 1,177
    edited August 2023
    Well, I was thinking about separate pane where I can see the change at tha same time.
    Anyway, why isn't dForce Modifier Weight Node included when saving a prop?
    Post edited by James on
    Anyway, why isn't dforce weight modifier included when saving a prop?
    Figure/Prop asset does not include dForce Modifier Weight Node but it saves the weight(s) in the dsf file of your hijab, so you don't need to include the weight node with it. If you do need it, save the hijba as a Wearble preset.
