Bryce + Lego = Fun
2
  • HoroHoro Posts: 11,616
    Hansmar - thank you. Yes, I know what you mean, it drove me almost crazy. I put the house far down to test but this dark line stayed. It seems to be a shadow.
  • adbcadbc Posts: 3,115
    Horo : great setup with the lego houses.
    Thank you adbc.
  • NGartplayNGartplay Posts: 3,415
    So much fun.  Enjoying the Leggo scenes.
    Thank you NGartplay.
  • mermaid010mermaid010 Posts: 6,209
    Thanks NGartplay
  • HansmarHansmar Posts: 3,194
    Here a render of two lego models in a nice room. I used the 'Quiet nook' from DAZ and a train from CGTrader and a car from Free3d. I textured the train myself (lot of work). I tried to add a sitting boy (from DAZ), but even though I had lowered the resolution of all textures, Bryce kept crashing. It did not want to include everything, though I am sure I made scenes with more MB in the past. So, in the end, I gave up.
    edited August 2023
    Hansmar Wow beautiful render the Quiet Nook is superbly light, nice idea to add the Lego toys
    Post edited by mermaid010 on
    Hansmar : I agree with mermaid, this is a really beautiful render.
    Hansmar - what a cool idea, and very nicely done.
  • Electro-ElvisElectro-Elvis Posts: 947
    edited August 2023
    mermaid010: Nice Lego-Dino-Picture
    Horo: Yes, exactly this way looked our first Lego houses (before we got the sloping roof tile blocks).
    Hansmar: Beautifully lit scene. Well done
    I took hansmar's question to heart and modelled complete lego bricks including underside/inside. The dimensions correspond to the original Lego bricks. I created (my first) OBP file, with my Lego bricks. There are a 2 x 2 nubs and a 2 x 4 nubs (the classic brick) bricks in eight different colors. I put them into an OBP file, you find the link for downloading it below. Since it is my first OBP file, I really hope that it is somewhat usable for you. Please let me know, if there are flaws in my OBP file. Maybe I will be able to fix them.
    I'm afraid, but I am not very experienced in offering links for downloading files. Because I have just OneDrive I uploaded my OBP file there. I hope you can access it with the following link
    https://1drv.ms/u/s!AnIfz3B2C2zEuS3_nh7Pu5OMsdKl?e=TGpYNW
    Lego Bricks Version 2
    Post edited by Electro-Elvis on
    Electro-Elvis - thanks for the comment and a big thank you for the blocks OBP file
    Elvis, download seems to work.
    Hansmar, what a clever way to showcase the leggos.
  • NGartplay: Thanks for your feedback.
    mermaid010: You are welcome.
    Electro-Elvis : thank you for the lego blocks.
    Thank you Electro-Elvis. The blocks work fine.
    I played with the blocks shared by Electro-Elvis, made a simple structure and added some freebie legos. The Simplon Hdri is the background.
    Thanks Electro-Elvis
    Great idea and well done, mermaid.
  • mermaid010: A little Lego country. Looks really nice
    Horo, adbc, mermaid010: You are very welcome.
    mermaid : Wonderful render, love the idea.
  • Yellow PenYellow Pen Posts: 921
    Hansmar - what a nice Scene.... beautiful work.
    Electro Elvis - Thanks for these Blocks... Download works perfect.
    Mermaid - beautiful Idea, and very well done.
    Thanks Horo, Electro Elvis, Adbc and Yellow Pen for the nice comments
    mermaid, such a fun image.  Very colorful too.
    Thanks NGartplay
    Mermaid, adbc, Horo, Electro-Elvis, NGArtplay, Yellow Pen, Thank you.
    Electro-Elvis, Thanks for the blocks.
    Mermaid, very well done scene.
    Hansmar thanks
    edited August 2023
    @Hansmar: You are welcome.
    I could not stop to making more bricks (From now on I call them bricks). In addition to the classic 4x2 brick and the 2x2 brick (2 studs wide and 2 studs long) I added six more brick types. And I tried to position them very close to the ground plane, so they can be used more easlily.
    More Legolike Bricks
    These are genuine Bryce objects. Because of the Boolean modelling, there could be some additional basic shapes that are no longer visible in the final product, but which create additional lines in wireframe mode and unfortunately can make everything a bit confusing. For the correct positioning I often used the top view and then used the studs to make sure the bricks lay on top of each other correctly.
    OBP-File
    https://1drv.ms/f/s!AnIfz3B2C2zEuTv6b2G4cebxT9jO?e=7ePe7e
    I also added an  Material Library, with nine different colours. The RGB values correspond to them Lego is listing in its colour tables. The Material Library should be listed, when you click on the link above. (hopefully). Please let me know, if you will face any troubles with downloading the both files.
    Thank you Electro-Elvis. I could download both files. I will add them to the library later. Thank you very much again.
  • @Horo: Thanks for the feedback.
    Thanks for the files, Electro-Elvis I downloaded them too
