Linday dForce Classic Long Side Bangs Hair for Genesis 9 issue
Hi all,
Just purchased this beautiful hair but having issues changing the textures. I've loaded a G9 character and then the G9 version of the hair. But when I use the G9 textures to try changing the hair colour I receive a message:
An error occurred while reading this file, see the log files etc etc.
The log has the following error:
2023-08-08 00:15:55.939 [WARNING] :: Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2023-08-08 00:15:55.939 [INFO] :: Error loading asset: F:/My DAZ 3D Library/People/Genesis 9/Hair/Linday/Classic Long Side Bangs Hair/Iray Materials/Black/CLSB G9 Hair 03 Black Darkest Violet.duf
Not really what  I'm doing wrong or how to fix it.
Any guidance would be kindly appreciated.
Thanks.
  • felisfelis Posts: 6,510
    It is a hieracical material preset, meaning that you must have the root node selected when applying it, i.e. the Genesis 9 character.
  • Thanks for your response.  I have tried that but it still presents the same message: An error occurred while reading this file, see the log files etc etc.
    There are separate versions for G8 and G9, did you use the correct version for the character?
  • ShadyNZLShadyNZL Posts: 4
    edited August 2023
    Yes, indeed. Loaded a G9 character, loaded the G9 version of the hair [Classic Long Side Bangs Hair G9], selected the G9 character, loaded a G9 texture eg CLSB G9 Hair 05 Warm Black... and that's when I receive the error.
    Post edited by ShadyNZL on
  • Was the hair fitted/parented to the figure? For hierarchical materials to work the item HAS to be fitted/parented to the correct figure.
    edited August 2023
    I just tried this myself, loading a G9 character and then loading the hair and trying to change the color, same, error and yes, it was fitted and the figure was selected
    Post edited by FSMCDesigns on
  • Yes, parented and fitted.
  • If there is a problem with the G9 version it might be worth creating a non-hierarchical material preset for the hair yourself. Load a G8F character with hair, apply the hair colour you want. Select the hair and then choose menu option 'File| Save As| Material Preset'. Having done that, the material preset should work on the hair when you have the G9 version of the hair selected, same as when you've selected the G8F version. Regards, Richard.
  • LindayLinday Posts: 89
    Hi, unfortunately there is an issue with hierarchical material presets for G9, we are working on it and corrected files should be out as update soon. Sorry for inconvenience, we understand that you want to play with purchased product right away.
  • Appreciate the response @Linday.  Love the hair and great to know you are working on it.
  • barbultbarbult Posts: 27,511
    I've used several of the G9 hierarchical presets for the hair colors, and I haven't had any errors. What situation causes the error message?
    This image has been resized to fit in the page. Click to enlarge.
    Hi, we don´t really know what causes this error, we tested it on 2 computers when the product was finished and everything worked just fine, tester in Daz didn´t have an issue, when this thread occured, we tried it on the third computer and the error was there. So we resaved all hierarchical material presets for G9 and submitted them as update.
    Thanks for the reply. I guess I have one of those lucky computers where the hierarchical material presets work fine. It is a nice product.
  • Arge7Arge7 Posts: 5
    edited August 2023
    Don't mean to hijack, but can someone please tell me what model is used in the promo pictures for this (wearing the black outfit with the gold wall background)? Thank you.
    Post edited by Arge7 on
  • P3DesignP3Design Posts: 132
    Having the same issue. Hope it will be solved soon :)
  • Have the same problem and wait for an update :)
  • alienareaalienarea Posts: 547
    Maybe those who have the issue could inform Daz/Linday about their computer specs and Daz release?
  • Make sure you are using the latest version of Genesis 9 Essentials, that was the fix for me.
  • When comes the update?
  • According to the readme page the update went live on Aug 15th
    "2023-08-15 - G9 Materials Updated"
  • ElorElor Posts: 4,115
    Oh, so that's where the changelog is. A nice thing to know smiley
    Thank you!
  • There seems to be so far no solution to this problem. I bought dForce Wet Messy Bang Hair in October 24, reinstalled by install manager in February 25, still impossible to change colors.
    Interestingly on 2 AMD CPUs it reports the above mentioned error, on Intel its working. Any suggestions?
