Are there any V4 or M4 texture presets for Iray?
jdavison67jdavison67 Posts: 690
I noticed there are Genesis 2 Male and female skin presets, but what about my V4 and M4 based characters?
JD
  • The Blurst of TimesThe Blurst of Times Posts: 2,410
    edited May 2015
    Couldn't you select an Iray-ized surface for G2M or G2F, generate a shader preset from it, and then apply the shader to a M4 or V4 surface?
    You probably need different shader settings for eyes and such, but that's not difficult.
    I plan to do some work with M4, so I can test that out later...
    Edit:
    This is what I'm taking about.
    http://www.daz3d.com/forums/discussion/56644/
    The question in the other thread is about applying Iray shaders to the G2M genital prop.
    I think the same principles apply to moving the shader set to M4.
    What you care about are the shader settings, which should not matter to Genesis versus Genesis 2.
    UV, skin textures... those are not the droids you are looking for. Shader settings shouldn't matter to that other stuff. That stuff should just fit on top of the shader.
    Post edited by The Blurst of Times on
