• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz bridge to Blender and back to Daz as morph
j11011j11011 Posts: 32
August 2023 in Blender Discussion
I've looked at videos of how the Z brush bridge works and am looking for a solution how to do that using Blender
Problems I'm having:
1) posing a character, then sending it to Blender makes the pose to be slightly off, not talking about jcms, talking about joint angles being off, what causes that?
2) even if this pose is slightly off, trying to send it back to Daz just doesn't seem possible, tried server combinations of settings, and either run into big distortions or it reverts to the standard pose
now, I'm familiar with standart pose export/import from Daz to Blender and back using Morph loader pro, hair morps, fixing other minor things that can be done in A or T pose,s culpting faces etc, I can do all that with no problems, the problem is that this bridge doesn't seem suitable for fixing things while having characters in pose for a scene, some things I can fix with meshgrabber, but it just doesn't compare to tools in Blender
in short - is it possible to achieve comparable functionality to GoZ using the Daz to Blender bridge and Morph loader pro?
  • Richard HaseltineRichard Haseltine Posts: 109,329
    August 2023
    For morph creation the OBJ route would be the normal route to take, rather than using the bridge (which is intended for sending content from Daz Studio to Blender - it isn't meant to be analogous to GoZ)
  • j11011j11011 Posts: 32
    August 2023 edited August 2023
    I tried that, but ran into an issue (that problem is not present when exporting to Blender via the bridge, which is why I asked about it in the first place) that when you import the obj in Blender, in object mode it looks fine (surfaces are smoothed), but once you switch to sculpt mode, surface loses smoothing, and the base mesh is way too coarse to be workable in that condition, smoothing is a MUST, I can apply a modifier, but that doesn't quite work and I'm not that proficient in Blender to figure out what is wrong, there don't seem to be any import options in Blender that help with this, and addition export options in Daz for obj also doesn't seem to say anything about smoothing
    edit: found the problem - in object mode right click and Shade Smooth, that fixes that issue
    But I find it very weird for the Daz to Blender bridge to not have this functionality back and forth functionality like GoZ, unless they do it on purpose to steer users towards payed Z brush, and I tried to use the free Zbrush version, and the cheaper subscription, GoZ doesn't work with those, it only works with the full one, which is not exactly cheap (nor necessary for the quick back/forth to fix collisions or make some small morphs)
    I had high expectations when I saw that there was update to the Daz2Blender bridge, only to find that it addressed none of this... when it seems pretty trivial to do considering where they are with that tool already
    so now on the wish list is an option in the OBJ export window to export everything in base resolution (so as not to forget to switch to base/high every single time for every single item you might need to bring back)
    edit: another wishlist item would be to be able to click a particular morph in Daz and have an option in context menu to update it from the source OBJ instead of having to dial it out, delete, reimport with Morph Loader again or importing it as another morph, that would be an extremely useful feature when you want to check intermittently the progress you're making, since sometimes how it looks in Blender is not exactly how it looks in Daz, despite setting viewport focal length to be similar etc
    Post edited by j11011 on August 2023
    August 2023
    GoZ is a standard system, the bridges are Daz' own development. The Bridges are for getting content into the destination application, they are not (currently, at least) intended as content creation tools. GoZ doesn't add functions that are not available through standard export/import, it's just a  convenience tool (and even there, it is limited in some respects - for example it doesn't preserve any grouping so using ZBrush for texturing either requires regrouping, which is not hard but a bit fiddly, or using OBJ).
    August 2023
    you can "create content" with the Daz to Blender already, send a default figure over, sculpt and bring back, that all worked, but what was missing (from Blender bridge), and IMO should have been there, was a quick and easy way to switch to, fix what was broken, and then bring back quickly, that is not "creating content", that is filling in the gaps in Daz functionality, like I said - fixing poorly fitting clothing, or creating depressions in soft tissue when character is sitting down on something, or interacting with another figure, because Daz obviously can't do that (and Meshgrabber is quite limited), and I find it weird that they don't fix things like this, which would make working with their figures and software a lot easier - which in turn makes users want to stay with them, instead of switching over to completely different software and probably ditching the Daz shop altogether, and the shop is what brings in the $$ after all
  • marblemarble Posts: 7,500
    September 2023 edited September 2023
    I send OBJ files over from DAZ Studio to Blender every day and I use Blender to create morphs. I have also noticed that change in resolution when switching to Sculpt Mode (which is what I use for making morphs as I am not proficient with the Edit tools). I just thought it was a quirk of Blender and I know that I am limited to the actual base resolution (no subdivision) of the exported OBJ from DAZ Studio. I don't have ZBrush but I had assumed that you would have to work with Base resolution there too - is that not so?
    By the way - I don't use any bridges to send content to Blender as I assumed that they (The DAZ bridge and also Diffeomorphic) were intended to transfer scenes for rendering or animation, not for morphing purposes.
    Post edited by marble on September 2023
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
