Geometry doesn't follow rigid follow node
James
I created a rigid follow node.
I parented my geometry to it.
But the position of the geometry wasn't exactly at the node.
What wrong with it?
Post edited by James on
Do you mean it moves after parenting, or that it doesn't match the changes in the followed area, or something else?
It moves after parenting.
Make sure parent in place is turned on - see image. If its moving when you pose the figure make sure the node itself is parented to the correct bodypart. For example if you have a node in the chest area but its parented to the hip area it will wobble around when you pose the figure. If its parented to the correct bodypart but still moves try testing with different polygon selections to get the best result.
Everything above is re-checked.
It moves only when parenting.
The figure in zero position.
I positioned the ribbon on the right place.
But when parented it moved.
Currently I just put it back to the meant place again.
not sure will that be a problem.
