Geometry doesn't follow rigid follow node
JamesJames Posts: 1,191
edited July 2023 in Daz Studio Discussion
I created a rigid follow node.
I parented my geometry to it.
But the position of the geometry wasn't exactly at the node.
What wrong with it?
https://prnt.sc/NLBBfBr1UxmR
Post edited by James on
  • Richard HaseltineRichard Haseltine Posts: 111,688
    Do you mean it moves after parenting, or that it doesn't match the changes in the followed area, or something else?
  • JamesJames Posts: 1,191
    It moves after parenting.
  • MadaMada Posts: 2,068
    Make sure parent in place is turned on - see image. If its moving when you pose the figure make sure the node itself is parented to the correct bodypart. For example if you have a node in the chest area but its parented to the hip area it will wobble around when you pose the figure. If its parented to the correct bodypart but still moves try testing with different polygon selections to get the best result.
    508 x 328 - 18K
    edited July 2023
    Everything above is re-checked.
    It moves only when parenting.
    The figure in zero position.
    I positioned the ribbon on the right place.
    But when parented it moved.
    Currently I just put it back to the meant place again.
    not sure will that be a problem.
