"V3D HDR Master Bundle" (Commercial)
17891012
  • I am using DazStudio 4.21 Pro on Windows 11, but it is irrelevant now.
    Because, what do you know! It worked!
    Well, I guess what i missed in documentation was that the Render Settings have to be set to NVIDIA modus. This was not the case first.
    Now it successfully rendered the exr, which was successfully converted to hdr (for Filament viewport), which then could be successfully loaded in a new Environment.
    Further it is the question of finding the right resolution and maybe other settings, but it works perfectly.
    So thanks a lot for your help! And this case is closed now.
  • V3DigitimesV3Digitimes Posts: 3,378
    Wooonderful. Concerning the resolution and other settings its so dependant of what you want to do that I let you find out what you prefer. Anyway it is a goid thing you mentioned this issue and its solution here. It may help other people and I will have a look if something can be done in the next update. Thanks for that!
  • jjoynerjjoyner Posts: 767
    @V3Digitimes, @barbult, @crashworship
    Hello.  I bought the V3D HDR Creator Bundle two months ago and started exploring with it a few days ago.  Unfortunately, I don’t think my modest system (Win 10, 16Gb RAM, RTX 2060 with 6 Gb VRAM) is up to the task of creating a high enough resolution EXR file to avoid a blurry image.  I have read many times the posts between the three of you in early April and nothing that I try gives me a sharp image at the resolutions that I am capable of rendering – so far, only 8K.  Perhaps if I use Scene Optimizer to reduce the RAM/VRAM needed, I can do better.  I’ll also try the png xEV Creator to see if I can get a sharp HDR file with my system.
    edited November 2023
    Hi jjoyner. Sorry you're having issues with the resolution you can reach. Indeed, if your hdr seems "blurry" you can have to main origins :
    1. The hdr size (resolution). It's not obvious to give a recommended size since, after you use the hdr in your scene, it will depend both on the "proportion" of the hdr you will see on your final render (like 1% or 10%??) and on the resolution and size of the final render you want to make. But resolution is not the only factor acting on the backgound looking sharp or not. But before you try to push the size too high you can try to increase the number of render samples to see if things go better for you, as explained just after:
    2. The number of rendered samples can also have a strong influence. But take care, taking account how Daz Studio handles the creations of those hdr so that they can then be loaded with the right "lightness" level, the renders tend to be super short with a minimal number of samples (and you cannot increase it easily). In this case I would recommend to use the render settings I provided, for render settings (I hope this still works in 4.22) :
    • a. OBLIGATORY: Set "Max Time" to 0 AND "Render Quality Enable" to OFF : this way, the number of iterations (samples) is only determined by "MAX samples".
    • b. Set the MAX samples at the value you want, if you made "a." then the render will stop at this exact numer of iteration, but you can safely cancel it at any iteration you want (provided you reached the Update Interval at least once)
    Of course you can try with the png xEV creator, but this function was rather introduced for environments using fog, haze, vdb, night scene, well.. "not classical" scenes. I would personally try to increase the number of rendering samples until increasing this number does not increase the hdr quality any more, then I would increase the hdr resolution until my video card cannot support it (or until I find it is too big on my hard drive).
    Let me know if you still have issues, you can contact me here or via MP this is the same for me :) and have a nice sunday!
    Post edited by V3Digitimes on
    Starting with 4.22.0.1, setting the Max Time to -1 disables the maximum time in seconds as a criterion for render loop termination. The maximum setting for Max Samples is 25000 (it can also be disabled by setting ot to -1).
    @V3Digitimes,
    Hello and thanks for your fast reply.  I’m a hobbyist at this stuff and now that I retired four years ago, I can “play” as it as much as I want each day.  I forgot to add in my original post that I'm using version 4.21 (I don't plan to migrate to version 4.22 anytime soon.) and that my laptop's processor is an Intel i7 (9th generation).
    As I wrote earlier, I’ve read and reread your conversation from early April and tried many of the suggestions offer by you and @barbult.  I’ve pushed render samples as high as the default 100 and lowered the luminosity setting in HDR creator. I’m still experimenting to find the right combination of settings (and patience with rendering) that gets me as close to where I want to be as possible.  I’ll use more of your recommendations to try to get there, though.  As I also wrote, that place may not be possible with the limited VRAM/RAM that I have.
    EDIT: One of the experiments that I tried yesterday was to try to create a sharp HDRI with just basic primitives in the scene to make the scene as light on RAM/VRAM as possiblle.  I loaded three cubes, changed the colors on each and changed the environment to Sun-Sky Only.  I did not change any parameters in the HDR creator script but still got a blurry 4K HDRI.  I realize that 4K is not optimal but I was hoping that with just three primitives in the scene, that I would get a sharp(er) output.
    On a side note, I want you thank you very much for Scene Optimizer.  I bought it two years ago and it is a mainstay in my 3D toolbox.
    Post edited by jjoyner on
  • ArtiniArtini Posts: 10,477
    I also got blurry renders with 4K resolution.
    Minimum acceptable was 8K, but 10K is even better.
    I am also limited by hardware on my computer
    (graphics card with 8GB VRAM, but at least Nvidia).
    I agree 4 k is most of the time to low resolution, except if you use the hdr to create small images like cartoon vignettes. I generally use like Artini 8 to 12 k resolution with on my side 200-2000 samples (depending if I launch them at night or not).
    @3DVigitime, @barbult
    If I could easily render at 10K or above on my RAM/VRAM limited system, I would definitely take that route but, both usually get maxed out along with 100% GPU utilization when I attempt to go higher than an HDR 8K render.  The render may still be happening but the render iterations slow to a crawl – perhaps 11 iteration after several minutes with hundreds of iterations to go.  That would likely take hours on most scenes and most likely on CPU only if I set Daz Studio to allow CPU fallback.  I can sometimes manage 8K depending on what is loaded with an object/scene.  I’m also using Scene Optimizer and Camera View Optimizer to try to help.
    On April 6 in this thread, you and barbult offered the following advice:
    3DVigitimes
    Indeed, when you load your exr, your camera sees only a "small" part of it, so you have to make sure your exr size is big enough.
    barbult
    Let me show in pictures what V3Digitimes said above. She is absolutely correct that the blurry pixelization is caused by the HDR dimensions (4000 by 2000 in your case) being too small for the zoomed in camera view you are using in your final 1920 by 1080 render. There are three options that I can think of. You can try one, two or all three.
    1) create a much larger HDR, if your computer can handle it
    2) don't zoom in so far with your camera (i.e. use a smaller camera focal length)
    3) render a smaller final image so the available pixels don't have to be stretched so much.
    I realize that there are many variables at play, but in general, what camera focal length (I’ve gone down to 35 mm) and/or render size might I try to help improve the situation on my limited system.
    Again, thanks much!
    I won't be able to help a lot about focal length. I don't worry about it when I render the exr, except when I use depth of field. When I don't use depth of field, I think I remember from my tests that I noticed no differences in the rendered exr. When I render my images using the hdr as a background image/lighting I don t worry about the focal lenght too because in general the size of the final is ok with the size of the hdr.... Ps: sorry for the eventual spelling errors I am on my phone (computer not available and phone with small characters, old eyes, and bad languge autocorrector).... Maybe users who usually make big renders or who cannot render big hdris because they don't have enough memory will be able to help you. Have you checked if teducing the dmme size could help?
    OK.  No, I have not experimented with dome size yet.  I will though.  Thanks.
    Not sure at all it will help even if my intuition says there might be a small improvement optimising the dome. But only a small... I am so sorry I have not a magic button for people who cannot render with the video card... :(
    No worries.  When I bought my laptop four years ago, its specs were fair for what the latest Daz Studio content required.  Now however, I have to be carefull with certain content because of their memory requirements.  A new system (perhaps a desktop) may be on the horizon.   :)
  • barbultbarbult Posts: 26,439
    @jjoyner the comment about using smaller focal length was aimed at the render that USED the HDRI, not the CREATION of the HDRI, if I recall. I'm traveling and don't have the bandwidth to write much now.
    @barbult - OK.  That makes sense in that changing the camera focal length in the creation of an HDR didn't  improve my situation.
    Yes, creating 10K HDRIs on my desktop takes also hours and the files are so big,
    so I am rarely creating a new ones.
    My hope is to learn using skyboxes in Unity
    and export them as a 360 degree panoramas in EXR format.
    I have not succeded to get enough light from them, yet.
    Exporting from Unity is very fast (less than a minute),
    but my graphics card limits resolution of the created HDRIs.
    I have not  succeded to create a HDRI with more than 6K resolution in Unity, yet.
    The other problem is, that in Daz Studio, the base of such HDRi is high in the air
    (in the middle of the height of the HDRI).
    Post edited by Artini on
    Something has changed in the 4.22.1.221 Public Build that causes the HDR Creator toolbar and menu item "6. Add or Redock Toolbar" to instantly crash Daz Studio for me. This does not happen in 4.22.0.16.
  • Hey barbult! Thanks a lot for letting me know! I'll have a look at this very fast, and if I don't find the solution on my own, I'll ask Daz Team what can happen. This is not the only product adding or redocking toolbars this way, so this is very annoying. I'll come with an update for all products as soon as I solve this!
    Thanks. smiley
  • Ouch @barbult I don't manage to replicate this, so there must be a difference between your and my configuration somehow...
    Here is what I did, tell me if I'm wrong : The difference between you and me may be that I "just" installed the menus and toolbars (they were not here before), whereas you had them before. It could also come from the "Main" toolbar not existing in your UI.
    Well I :
    - Updated Daz Studio Public build and checked the version I now use is : 4.22.1.221
    - Downloaded via DIM : HDR creator.
    - Opened Daz Studio, and launched "V3DHDRC01 Install" : the toolbars and menus were installed there were no worries
    - via both the menu and the toolbar, I played with the 6 and 7 "redock" and "remove", I never had a crash... I restarted Daz, replayed, still no issue.
    - I tried with other "newly" installed "readd or redock" of another product, (built on the same script base), no issue.
    . In the changelog it seems there were modifications in the panes, but I don't really see where it could make it fail. It is going to be hard for me to solve if I cannot reproduce the issue, and I will need your help if you are ok for that, to see where it comes from.
    Could we try to solve this together so that I can see if I can develop an update for people in the same situation ?
    - Have you tried the "remove" before the re-add/redock?
    - Have you tired to "remove", then restart Daz Studio, before the re-add/redock?
    - Do you have the "Main" Toolbar in your interface, I must confirm but I think I add the creator toolbar at the right of the Main toolbar.
    - What if you re-use the "V3DHDRC01 Install", then restart Daz Studio, does it change anything?
    Thanks for any help you could have on this topic :)
    • I have not tried and documented the results of all the things you have suggested. I will try some of those.
    • What other product should I try dock and redock on, to see if it is just the HDR Creator that I have trouble with?
    • I have lots of toolbars, but I don't have the Main toolbar active. I have Pose Splitter and Pose Master off right now, because I am running out of space for all these toolbars, but I could turn them back on if I need to try them.
    • If you want to email me an unencrypted verson of the dock and redock script, I could try to step through it with the script debugger and see where it fails. But if it doesn't happen for you, there is probably some conflict between things I have installed or the way my workspace is configured.
    282 x 502 - 30K
  • It may be worth trying a clean UI (save your existing layout of course) - given your issues with custom scripts going AWOL after updating menus and now this I wonder if there is some corruption in your files. You can also use an instance with a different name and its own layout as a way to check Daz Studio Pro 4.12 - instances without running the risk of saving and reloading a layout that may possibly have issues.
    edited September 2024
    - yes, the first idea is to check if it comes from the fact that you already had a the menu before the update.
    - from what I remember you have the same "redock" in hdr addon tools, in pose mixer pro, for the rest I would have to check.
    - from what I tested (rapidly), not having the "Main" toolbar is not an issue.
    - Ohhh! I just managed to have a crash with the redock of "hdr manager"... Let's try to replicate! OK, it seems that I manage to replicate this ;) I'm gonna make some additional tests, and if I manage to solve anything, I'll send you the new file so that you can test it...
    edit : I just see your message Richard. I'm having a look at what is going on with the script from the menu which crashes my Daz Studio, the issue I'm having is that it crashes when it is launched from the menu, but the dsa I kept does not create the crash when launch from the script IDE... This is a bit complicated.
  • I made more tests on the "redock" script. Each times it works perfectly from the console, each time it fails when launched from the menu. I'll have a deeper look later on, but I think I'd better ask Daz Team if they have an idea what in their updates could cause that. If I find no solution, I'll test if I can repair it by replacing it by something with another approach. If not, the redock script will be remove and each time people will have to reinstall the files with the initial script, which is an idea that I hate.
    I'm not sure in what version of DS it started failing. It is not something I use frequently. For me, it crashes in the latest beta from both the menu and the toolbar. It does not crash from either menu or toolbar in DS 4.22.0.16.
    zip
    zip
    DAZStudio_error_report_240926-133330.zip
    107K
    I loaded Hollywood Blvd. layout. I ran the Install First script of the V3D HDR Creator to install the toolbar. I clicked on the toolbar icon to  ReAdd or ReDock the toolbar and DS 4.22.1.221 instantly crashed.
    I loaded Hollywood Blvd. layout. I ran the Install First script of the V3D HDR Creator to install the toolbar. I closed DS. I reopened DS. I clicked on the toolbar icon to  ReAdd or ReDock the toolbar and DS 4.22.1.221 instantly crashed.
    Once V3D was able to reproduce the issue my suspicion was obviously misplaced, it was only when she couldn't get the same issue that i suspected it might be something local.
  • Richard, well that's almost that, barbult got this issue with the "reinstall-redock" script of the hdr creator, and for me it works perfectly, but it crashes with the "reinstall-redock" of the hdr manager for me. So there is something happening after one of the recent updates that generate a weird behaviour. I wonder if it comes from the fact that the reinstall script also reinstall itself. But in this case, why wouldn't I have issues with all the reinstall-redock which are built on the same base script in all my product? (only the toolbar name, menu name, and files called change). This is a real mystery.
    @barbult : new input : The hdr manager which crashed was installed with DIM, whereas the other versions which work were installed with Smart Content. I uninstalled it and reinstalled it with Smart Content and it works. Tomorrow I will send you anyway the unencrypted version of the script. My guess (I may be wrong) is that it could work launched from the script ide, but once encrypted and launched from the data folder, that it might crash Daz Studio. And let me know if installed with Smart Content changes something. Depending on your answeres, this could give me a confirmation of what I fear (the file putting itself as a menu/toolbar item could be an issue, but only for DIM installed files???).  I don't really know how I could handle the problem, and wether I should remove the scripts, or update the documentations, or... I don't know... I still don't understand why it failed when installed with DIM and worked when installed with Smart Content, and I still don't know if there will be an impact on your side.
    OK. Didn't want you to think I left stones unturned. I always appreciate your advice.
    Smart Content(Daz Connect) installs to a completely different folder structure. I no longer use Daz Connect, because it caused me so many problems. This is actually the first time I have ever heard of a script working in Daz Connect and not DIM. It is always the other way around. At this point, I am not willing to install anything with Daz Connect. I'll see if the script debugger tells us anything first.
