DS 4.8 Iradium - Manual Download impossible?
2
  • NovicaNovica Posts: 23,925
    jag11 said:
    Too late for me. :shut:
    No, as mentioned, go to your Product Library and manually download the files. As long as 4.8 isn't in the Product Library yet, you can still save your 4.7 version :)
  • RogerbeeRogerbee Posts: 4,460
    There's still time! GO!!
    CHEERS!
  • jag11jag11 Posts: 885
    lee_lhs said:
    jag11 said:
    polka dot said:
    Novica said:
    DO NOT INSTALL 4.8 UNTIL YOU SAVE A COPY OF YOUR 4.7 !!!!
    In your Product Library, the 4.7 will eventually disappear because there is a new studio version released. Always save the previous version files before you install the latest, in case you want to go back and use the old version. I always download all the things shown underneath the Studio on the page, as I don't know what changes from version to version (I believe the GoZ must match the version with the version.)
    You are so right! I always save a copy of the earlier DS version - just in case.
    Has the 4.8 version already been released?
    My latest news was that you still can download 4.7, as 4.8 hasn't been sent to the servers yet....
    First, I uninstalled 4.8.0.55 beta but I don't have a saved copy of that version, so I'll have to wait until proper release.
  • BeeMKayBeeMKay Posts: 7,019
    Ah... but if they haven't changed the versions on the server, chances are that you can still re-download the Beta?
  • Richard HaseltineRichard Haseltine Posts: 111,192
    The Public Beta may still be available for download though DIM, if you deleted the zip after installing (by default DIM keeps the zips).
    Thanks guys, it's there...
    20/05/2015  08:21 a. m.       244,863,900 IM00012000-02_DAZStudio48PublicBetaWin64bit.zip
  • Digital Lite DesignDigital Lite Design Posts: 728
    edited May 2015
    In the meantime, for those worried about having to purchase shaders, documentation etc.... There are at least 6 threads dealing with the beta version of DS (with Iray). Those will have 90% of your questions answered. Many surfaces convert well. The threads also have a huge amount of info on tweaking the surfaces that do not convert to your satisfaction.
    While I know that is a lot of reading, if you want to use Iray it is well worth your time. If you don't want to read....then you are passing up a huge amount of help the people who jumped in on the beta are providing. (As well as DAZ employees)
    There is also documentation. Yep, real documentation. :)
    Iray Uber Shader:
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/interface/panes/surfaces/shaders/iray_uber_shader/start
    Render Settings:
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/interface/panes/render_settings/engine/nvidia_iray/start
    Pay particular attention to the Tone Mapping section. :)
    Post edited by Digital Lite Design on
  • Bobeagle77Bobeagle77 Posts: 164
    Same.I can't download manually. I don't like extra unnecessary software running in the background like DIM.
  • DAZ_SpookyDAZ_Spooky Posts: 3,100
    DIM does not run in the background.
    Files are syncing to the server. Should be available for download within an hour. Note that files downloaded before fully synced are likely to be corrupt. If that happens please re-download.
  • DzFireDzFire Posts: 1,473
    Thanks Spooky and a thanks to Kat too
  • DaWaterRatDaWaterRat Posts: 2,887
    Thank you.
    (Makes mental note to download in about 4 hours... just to be safe)
    edited May 2015
    On the subject of the manual downloads, why does that page nag and nag and nag at me to register and/or log in — I'm already logged in, every other page in the entire store sees me as logged in, why not this one? And why is the manual download link a tiny little bit of text while the DIM and D|S downloads have big bright buttons?
    And the servers have just updated! Going to be a bit busy for the next little while downloading and installing. :cheese:
    Edit: Aren't there supposed to be Iray goodies in a separate download? No sign of it here.
    Post edited by SpottedKitty on
    The Content is still getting some final tweaks. Please continue to use the Public Beta Iray Content until we get that to you.
    edited May 2015
    DIM does not run in the background. Oh my bad, Sorry. I thought it ran in background. I try to keep my computer running with minimum processes.
    Post edited by Bobeagle77 on
  • Ghosty12Ghosty12 Posts: 2,093
    edited May 2015
    Well can say this much DS 4.8 Release is a big sucker weighing just over 233 megabytes.. :)
    Post edited by Ghosty12 on
  • amulackamulack Posts: 11
    The manual download of DS 4.8 Final still does not work for me. Can anyone tell when the download will work. Why it does not work?
    Thanks!
    What happens when you try? I'm downloading it right now and it's going ok as far as I can tell. And yes, it is a beast, and that's even without the Iray content. I won't install till I have everything I need.
    CHEERS!
  • HoMartHoMart Posts: 489
    still cant tell
    still downloading - @ 125KB/s - on a 50mbit line :(
    edited May 2015
    still cant tell
    Yeah was very slow guessing the servers are getting hammered but I did get it finally and using it now.. :)
    Render I just completed that I posted in another thread took 3 minutes to render but it is a fairly simple scene.. Main thing was testing out the HDR settings.. :)
    851 x 1251 - 481K
  • mrposermrposer Posts: 1,137
    Will Dim uninstall the beta version of 4.8 automatically or should we tell Dim to uninstall it.
    Install Manager will not uninstall the Beta version of the software unless you tell it to.
  • Stryder87Stryder87 Posts: 899
    edited May 2015
    I just checked my Product Library and mine has changed to 4.8 as well. Boooooooooo.... I want a backup copy of 4.7!!!!
    Actually, the serial showing is still for 4.6. Is it going to work when I do the fresh install of 4.8 (I didn't do the Beta)?
    Post edited by Stryder87 on
  • vwranglervwrangler Posts: 5,039
    So if you didn't install the public beta, does that mean that you should hold off installing 4.8 until the new content is ready?
    So if you didn't install the public beta, does that mean that you should hold off installing 4.8 until the new content is ready?4.8 works without the content. You can still get the content though, as the Beta content is still available.
  • MN-150374MN-150374 Posts: 923
    edited May 2015
    Downloaded the Default Light and Shaders Package. I would have thought, there is an update to it.
    The Iray Shaders and Lights are still from the Beta Download Page? Or will there be an update to the Default Light and Shaders?
    Edit: Oh, I see. My question is already discussed.
    Post edited by MN-150374 on
    There will be an update to the content. It is not yet available.
    Thanks for the quick reply.
  • caravellecaravelle Posts: 2,762
    Download completed! Maybe I should wait for the updates before installing DS 4.8.
    edited May 2015
    Any DS 4.x Pro serial number works - the very old versions of DS 4, before Pro was free, won't accept the newer serials (SDZFPRO) but that has been the only change.
