SOLVED -- How to get rid of "green film"
HeraHera Posts: 1,960
edited May 2015 in The Commons
Hi!
After installing DAZ on my new computer, every item in the viewpoint has suddenly begun to get covered in a "green film" whenever I hover across it.
Is there a way to get rid of this feature, which does nothing but constantly annoying me and slows down my work since I have to hover out all the time to actually see what I'm doing?
Post edited by Hera on
    If you are using DS4.7, go to Window > Panes (Tabs) > Tool Settings, and under 'Draw Style' select Bounding Box Only.
    If using DS4.8, then there is a separate Draw Settings pane, and you can set the Draw Style inside it.
  • HeraHera Posts: 1,960
    Thanks Jimmy for a rapid & clear answer. A big digital kiss coming your way! :kiss:
    Ooooo!
    Thank you :)
