UltraSceneryXT - large terrain/landscape generator
1323335373842
  • DoctorJellybeanDoctorJellybean Posts: 10,110
    edited June 2023
    Somewhere in the tropics
    Thanks to the tip by @barbult the Archipelago preset turned out quite nicely.
    Please right click the image and select view in new tab\window to see it in the proper resolution.
    Post edited by DoctorJellybean on
  • ArtiniArtini Posts: 10,904
    You just right click on the image and choose width less or equal 800 pixels.
    which is a maximum width that forum allows.
    Ah, thank you.
  • barbultbarbult Posts: 27,508
    I always marvel at how much you get into a scene. I even see the helicopter.
  • davesodaveso Posts: 8,256
    edited June 2023
    a simple scene.  I've been back at trying XT ... I still think its difficult to manuever it.
    finally got it uploaded
    800 x 640 - 836K
    Post edited by daveso on
  • AnEye4ArtAnEye4Art Posts: 867
    Nice work.
    I call this 'remote island'.
    1800 x 1112 - 3M
    Great images, everyone.
    edited June 2023
    Another island. This time with a cove.
    1800 x 1112 - 4M
    Post edited by AnEye4Art on
    Nice one, @AnEye4Art
  • MartinjfrostMartinjfrost Posts: 434
    The Ultrascenery XT Desert  Moduel is out now!
    Loads of new settings, and a perfect background to the US Desert Bundle.
    Great, that it is for UltrSceneryXT. Looking forward to experiment with it.
  • alexhcowleyalexhcowley Posts: 2,409
    Martin, if anything, undersells this product.
    There's 8 new terrain presets, 3 vegetation biomes, 3 water shaders, 4 cactus props and 5 material presets.
    https://www.daz3d.com/ultrasceneryxt--desert
    Cheers,
    Alex.
  • Already bought. I can't wait to check it out.
  • Has anybody gotten the desert presets to look like the thumbnails? I'm getting a lot of level plains.
  • paulawp (marahzen)paulawp (marahzen) Posts: 1,797
    edited June 2023
    From the "And now for something completely different" category to do quick, low-effort test of the USXT desert, which I just got installed.
    No, I'm seeing mountains. The immediate foreground is USC desert but everything beyond the river is USXT.
    1300 x 1000 - 1005K
    Post edited by paulawp (marahzen) on
  • DaventakiDaventaki Posts: 1,624
     Is it all presets?  If so might reinstall the pack. I only tried the one due to time but will check later.
    1884 x 922 - 2M
  • Yeah, the presets are the problem. I've done a few by hand that worked, but the presets got me nothing. Salt Lake, for instance, looks like a big flat white box.I've uninstalled, reinstalled and tried both DAZ 4.21 regular and Beta. Same thing. Hmmmm.
  • Looks like the second reinstall of Ultrasceneryxt has done the job and I've got mountains. Yay!
    yesyesyesyesyes
    In the cart, soon to be on a screen near you.
    edited July 2023
    To be fair, Ultrascenery Desert is really the star here, but there's USXT Desert in the background, doing what it does.
    1300 x 1000 - 794K
    Nice image, and well used products, thanks for sharing them!
  • Steel RatSteel Rat Posts: 417
    Coming back to trying yo use this after a hiatus. Fresh install.
    I can get the terrain to generate, but none of the terrain maps seem correct.
    This is the Vernon preset, which should be snow-capped peaks with green terrain. No matter which preset or terrain material I use, it comes out like this.
    1200 x 1200 - 3M
    edited July 2023
    After you selected the Vernon preset, did you click the Apply button to apply the selected preset? If not, it won't "take". I've forgotten to click Apply more than once. blush
    I don't think your Vernon looks that far off. I see the green "grass" area on low slope areas. Snow will only be on high peaks (you can change that in the surfaces settings). Rotate your camera around and see if you can find a snowy peak. I see snow when looking at the Front view in my Vernon render.
    2000 x 1125 - 2M
    Post edited by barbult on
    Well, I kinda expect a preset to look, y'know, like the preset. It isn't anywhere near as green as it should be, and no snow anywhere. And yes, I did hit apply. I had to do a LOT of fiddling with the surfaces to get any snow at all to show, and even then not very much. The other snowy presets aren't much better.
  • richardandtracyrichardandtracy Posts: 8,049
    There are two things you need to do, set the ground colour and the ecology. I've missed setting the ground colour before.
    Regards
    Richard
    Regards
    Richard
    Presets do that automatically. Or at least they should. If not, can you specify where that is set? Thanks!
    Yes, presets do that automatically. It is still a mystery why the Vernon preset has snow for me but not for you.
    i think it might depend on where the camera is pointing. Also how high the terrain is above the ground plane. its difficult to position the USC and XT with the size ... in my opinion. Is there a way to lower or hieghten the ground plane?
    It's an even bigger problem when you have to have your main characters near 0,0,0 to prevent iray artefacts when rendering.
    I did lower the XT set because of this. So maybe that has something to do with it. The biggest downfall of XT is camera placement, IMHO.
