• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic: Bendy Buttocks & Swollen Thighs (Vice Versa)
csaacsaa Posts: 953
June 2023 in Blender Discussion
I've noted distortions in the thigh and buttocks areas of the G8.1 I import from Daz via Diffeomorphic. With exteme poses, the mesh becomes bloated. In the Daz store I've seen Bend Control for Genesis 8 Female(s) which I believe remedies the problem in Daz. Can anyone suggest any quick and easy technique to do the same in Blender?
Cheers!
  • PadonePadone Posts: 4,055
    June 2023 edited June 2023
    From your picture it seems you didn't import jcms, or not all of them. Most figures provide additional jcms that you can load with "import baked correctives", or as custom morphs. If you load jcms in rest pose you should get the same deformations as daz studio. Then to adjust deformations that you don't like you may try with a smooth modifier masked by a vertex group to only affect the parts you want.
    Another way is to use a corrective smooth instead of jcms, eventually prebending the figure. Works fine enough if you don't need too much realism.
    https://diffeomorphic.blogspot.com/2023/01/using-pre-bended-figures-also-works-for.html
    Post edited by Padone on June 2023
  • csaacsaa Posts: 953
    June 2023
    Padone,
    Thanks for the tips! I re-imported the G8.1 figure with JCM option set and loaded the pose. This time the figure morphed well. My question now: is there a way to import the JCMs for a figure I previously imported from Daz without JCMS? I've gone on to customize the figure in Blender and I'd like to avoid having to repeat the work with a freshly imported one.
    Related to all this, the Diffeo blog talks about JCMs specific to the Genesis figure. Looking through the Daz application file system, I found many wardrobe DUFs with the "JCM" label in their file names. When we instruct DIffeo to import from DBZ with the JCM option set, does DIffeo gather the JCMs for the wardrobes as well?
    I ask this because I see the wardrobe belts squished in a way I do not with the same figure and pose in Daz Studio. My thoughts are that if we can import JCMs for a figure into Blender, why not the JCMs for wardrobes too.
    Cheers!
    June 2023
    Sure, you can import jcms with morphs > import standard morphs, then to transfer the jcms to the outfit you use morphs > transfer shapekeys, the vendor morphs will be used when available. Or just select the options in easy import for a new figure.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Setup/Morphs
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
