Show Us Your Iray Renders. Part III
1212224262750
  • tomtom.wtomtom.w Posts: 140
    Erdehel said:
    Well after some more testing IMO caustics are too unstable to be usable on a character.
    With default IRay render settings and headlamp on 'Auto' I took a Genesis 2 male. Then I applied the Jarek IRay default body and nothing else. The IRay preview was OK. then I used 1 body morph (not Jarek's) the preview was still ok. Then a second body morph (still not Jarek's) and the preview made Studio crash. In a previous test Studio crashed after the fifth or sixth body morph.
    I don't know if that product has been tested with caustics on.
    I give up. I can't determine what is going wrong without extensive testing. I'll open a ticket if I can remember how one does that :)
    Odd. The character that I used when testing my installation, using caustics without being able to crash DS, is an own character created from Genesis 2 base female, in a total makeover of every part of the body, using just about every morph I have.
  • Oso3DOso3D Posts: 15,104
    A new (Iray powered) page is up for my webcomic:
    http://thefarshoals.webcomic.ws/comics/23
  • AlexLOAlexLO Posts: 193
    edited May 2015
    I'm also putting in a ticket because I'm able to repeat this behavior anytime a Genesis is in the scene & caustics are turned on. It will either crash DS if a viewport is in Iray mode, or when going to render with viewports in any other shading mode. It doesn't crash on simple primitives made of glass, water etc... with caustics turned on.
    I'll then try a complete clean download & install of the beta instead of an overwrite to see if that sorts things out at all.
    The support center bug reporting page is at https://helpdaz.zendesk.com/requests/new & can also be reached from http://bugs.daz3d.com which will redirect you to the Zendesk support.
    MEC4D said:
    BTW anybody beside Alex noticed that when using caustic in the new build it crash every time you try to render ? I put just genesis in the scene .. and puff DS is gone ...... with simple primitives it works as well just not with genesis :(
    Post edited by AlexLO on
  • BestmanPiBestmanPi Posts: 22
    I tried, but I do not know how god rays, volumetric fog effects or volumetric lighting in IRAY. Could you tell me some tutorial or some way of doing it?. Thanks!
    This is my last render. With volumetric effects, he would have been much better.
    1920 x 1080 - 886K
    Thank you so much, Addict. I had searched but did not find it.
    Addict is a forum ranking SickleYield is the member's forum name :coolsmirk:
    Whatever you say, Administrator. ;)
    Well that's better than some of the names I have been called :roll:
  • Joe.CotterJoe.Cotter Posts: 3,362
    Kyoto Kid said:
    ...well, some bad news for those waiting on the 8GB GTX980 TI, Apparently, due to production issues, the planned release has been moved back until sometime in 2016 (no specific quarter mentioned). This is the third schedule slip since it was announced last year.
    Also, unlike the Titan X which saw only a modest price increase over the Titan Black,, the projected price for the 980TI is to be somewhere in the 800$ - 1,000$ range. For comparison, the 12 GB Titan X is currently available through Newegg for 1049.99 USD.
    So it's either go with 4GB or pony up the extra 500$ for a Titan X (Still much more affordable than a Quadro K5200 or K6000).
    Or buy the notebook that already has an 8gb 980 in it for little over $2k. I'm waiting to see if they come out with a skylake version myself or I would have already bought it.
  • MEC4DMEC4D Posts: 5,249
    You made me smile hahahaha too funny the whole situation
    Found the Caustics issue, it only crash if one of the materials is not converted to Uber base , other way it does not crash no matter G2F or G2M the same , I had my eye reflection set off and not converted
    Just thought I'd show what a finished render of the dark skin looks like, with the modified "glossiness maps" (V5Bree specular maps changed to gamma 2.0 to increase the difference between the brightest and darkest parts of them). It's just the top part of the render though, since she's barechested in the full image, so you'll have to go to http://tom2099.deviantart.com to see more of her...
    800 x 640 - 554K
    GTX GPU get damage quick when the temperature is at 80C too often and notebook can't provide enough cooling to prevent it
    Notebook have 8Gb 980M what have less power and less cuda cores than the Desktop version if I good remember ...500 less cuda cores
    GTX 980 is already forgotten for $200 more you have the fastest gpu from the gtx series
    Double checking & it seemed to work at first with a new scene, and checking to make sure all mats are converted (testing with the uber base & then applied the default Gen2 Male mat Iray settings), in preview everything held up, but when going to render, it still crashes :-( last night's scene crashes with Caustic Sampler, no matter what, and all materials were already converted)
    I thought maybe it was the backdrop option that may of been the issue, but I get the crash again with the backdrop completely removed & just the default dome active. It looks like the issue is the headlamp, which I positioned as a fill light. turned off & I was able to send the render through with Caustic Sampler on, but as soon as I turned on the headlamp, and have the viewport to iray, or send to a render, it crashes. Adding this new info to my bug report along with the crash files.
    It's the "deer in the headlamp" bug heh ;-)
    I've rendered G2F-characters where lots of surfaces used old shaders, without DS 4.8.0.55 crashing...
  • HoMartHoMart Posts: 488
    May I point you ( all the iray specialists in this forum) to this post
    http://www.daz3d.com/forums/viewreply/822854/
    (link to prevent doublepost)
    Has anyone here in the forum have any idea what might be happening here?
    Many thanks in advance
    edited May 2015
    About heating, yes notebooks have heating issue but I have a Microcenter that sells this with a walk in replacement near so this is not as much of an issue, but still one of the main reasons for waiting for the Skylake processor as this processor specifically addresses this.
    About the 980m vs the desktop, Tom's hardware had comparisons between this and the desktop 970/980 and it was between the two in performance, as well as including 4gb more on board memory. In the past, desktop and mobile chipsets (processors and video) have been significantly lower in performance, but this has shrunk quite significantly over time. The heat issue is my main concern anymore, and that, as I mentioned should be addressed with Skylake.
    In the spirit of full disclosure, I should mention that being mobile has become more desirable for me as of late so that effects my choices. If I were looking at staying in one location in the future while working, I might be looking to a different solution. In a related note, cloud based rendering will become something that many people might find play more a part in their overall work flow. I am not currently looking towards it myself, but neither am I ruling it out. With the speed of change of technology seeming to continue to increase, my decisions have changed over the years.
    Post edited by Joe.Cotter on
  • LyonessLyoness Posts: 1,640
    no problem. I had this problem too.
    I posted the solution in your thread.
    Thank you for the quick doubleanswer.
    You should use Fresnel IOR for reflections but not index of refraction
    and if you have problems with the view port changing the setting under preferences to quality may help too
    When I use a light with "geometry," it is casting a dumb-looking shadow in the shape of the light geometry. Is there no way to stop this while still using light shapes?
    I understand your personal choice as a hobbyist , here is nothing to argue about , I render and model all day long so I need more than that . People make mistakes thinking higher performance will render faster , for games yes as it is live performance.. it working little different with GPU rendering here ..but it really does not matter as I am going for the stuff I need for my work that I do for the last 17 years so I know what I need based in my budged plus I build my PC myself .. so my opinions are based on my own experiences not Wikipedia or google search , but still it is just my own opinion only, not mean it is the best choice for you or others .. just saying
    plus I have 2 laptops that cost double the price of my new PC set .. well failed with heavy GPU rendering for my work it is just not made for that even with separate cooling .. and I guess if I took your notebook for a 12 hour spin the cover will melt lol trust me on that
    even if you set to not render the geometry ? I wonder how it looks like the dumb-looking shadow in the shape of the light geometry lol
    edited May 2015
    Post deleted because it is not pertinent to everyone here.
    Ha! Render emitter was on. What a derpface. Thanks for the reminder. ;)
    No, wait. When I turn render emitter off, it's still doing it. It's weird.
    489 x 437 - 68K
    407 x 371 - 95K
    now it is really weird .. need to see it for myself
    edited May 2015
    Greetings,
    I'm having a 'DERP' moment myself; I have a character whose glasses I've rendered as glass. There are two layers (outer glasses, inner glasses), but both are set to a glass material. (Thick, I think.) They render as transparent enough, which is awesome, but they cast a dark shadow (?!?) on my character's face...
    That's just...weird.
    Any ideas?
    -- Morgan
    Post edited by CypherFOX on
    Turn the Thin walled On, conventional plastic lenses have a refractive index of 1.50,for real glass, it's 1.52
    make sure the specular is on Scatter and transmit
    Cypherfox said:
    Greetings,
    Any ideas?
    -- Morgan
