GET DAZ STUDIO 4.5! See why you should do it today!
1141517192033
  • fixmypcmikefixmypcmike Posts: 19,684
    inquire said:
    I don't understand the issue - download the current free Pro version and install it, enter the serial number, and use it.
    Richard: You do NOT understand the issue?
    Why there's confusion for users of DS4Advanced in particualr, no. Pro includes all the features they currently have, so they just download that and carry on.
    OK! So may I ask, rather than pour through the whole forum again, apart from installing DS 4.5, and I presume 'Genesis Starter Essentials 1.3' which I understand updates Genesis in some way or other, what else amongst the plethora of files I have downloaded do I also need to install.
    Such things as 'Decimator', 'GoZ; I'm not too sure about although having checked them out, they do seem to simply be extra plugins.
    Addenda:- This business of only having one version on your system is actually Tosh! Whilst admittedly I have multiple drives and partitions, I have had for some time:- DS2, DS3 32 & 64, DS4 32 & 64 all working without any conflicts.
    You can still have DS2, DS3 32 & 64, and DS4 32 & 64 all installed. You cannot have 4.0 and 4.5, just as you can't have 3.0 and 3.1 or 2.0 and 2.3
    kayma said:
    What the heck is this ".duf" format - and how come I can't save scenes in the old format?
    I recently "upgraded" to DS Pro 4.5. I can open my scene files okay, and I can access all my old content - and the auto-fit feature even seems to have been improved.
    However, I CANNOT save these scenes in the old .daz file format. The ONLY option I'm given is ".duf." When I relaunch the application, I can't even see these when I select "open." The only way I am able to access them is when I open a scene and choose "Save As" (which I can only do in this dysfunctional format), then click on it, choose "Open" - which launches a 2nd instance of DS - and close out of the first one.
    When it comes up, I get the following message: "Some assets needed to load the file were missing. The content may not work as expected. The following files could not be found:"
    Then it lists the Genesis .dsf files.
    When the scene finally loads, this is what I get (see attached screenshot).
    Why do you people keep trying to fix things that aren't broken? 4.0 had some glitches, but at least it worked.
    If you save the .duf to a DS-format content folder, it will show up there. It will also show up in Categories>Default>Unassigned, from which you can categorize it wherever you like to keep your scenes.
    As was explained, you need to install the Genesis Starter Essentials, which are now a separate installer from the actual application.
    At first I WAS impressed with teh speed of 4.5
    Until i tried to use something other than genesis that is. took over 10 minutes to load V4. TEN FRICKIN MINUTES. And there's a lot of lag trying to open non-genesis stuff.
    Do we need to reinstall GenX? will it still work with 4.5?
    If its broken I'm throwing Daz out the window until its fixed. I *NEED* genX. There's just not enough Genesis content yet without it. Do we also need to reinstall the iconic shapes for converting clothes?
    That's very strange -- V4 loads a lot faster for me in 4.5 than it did in 4.0 -- about a minute from the .cr2 with every morph set included in Powerloader.
    GenX is being updated for DS 4.5, D3D has a thread about it. I don't know if he's announced an ETA yet.
    The Gen 3 iconic shapes do not need to be updated.
  • edited December 1969
    Will 4.5 automaticlly grab my My Library folder? will it still see my Content folder for older stuff? It says it will uninstal 4. Should I copy any folders?
  • bighbigh Posts: 8,147
    yes - yes - no
  • DisparateDreamerDisparateDreamer Posts: 2,520
    It shocked me too... Genesis stuff was loading a lot faster in 4.5 than in 4. The overall speed of 4.5 was definitely faster (and yes much faster renders and spot renders!) but then I loaded V4..... Maybe it was a first time thing? Will test it when its done rendering. I have DS3A and DS4.5 open same time and i know from experience if I open one more DS4 it'll crash everything. poor computer!
  • LeggyBlondLeggyBlond Posts: 124
    edited August 2012
    Ah!.................................I See
    After all the questions and concerns by myself and others on installing DS 4.5 the following may be of help:-
    DS 4.0 Advanced was my current installation 32 & 64 Bit. On running both installers plus Genesis Starter Essentials 1.3 I now have it seems DS 4.5 Advanced. The installers used as they are which uninstall the old version simply did an update which of course required no serial number's.
    From what I have read here (someone correct me if I have misunderstood), to install the DS 4.5 Pro version I assume one has to do a full uninstall of the older version 'Prior' to running the installer.
    According to some mails I received from the Help/Contact Us (had I used the latter process) I would have got DS 4.5 Pro without any extra charge.
    Can anyone comfirm this?
    Post edited by LeggyBlond on
    If you 'bought' DS4P 4.5 upgrade from the store, you should have the full version including plugins in your downloads section. There is also an earlier version (4.0.3.47) as well which you can also download. You should then have a serial number in your My Account area for DS4P, which should change Advanced to Pro if that is what you mean?
    When installing the 4.5.0.114 upgrade, the installer will remove any previously installed version of DS4, and also the Basic Genesis files that used to be inluded in the main download . You must then install the Genesis Essentials file which also comes with the 4.5.0.114 download files.
    DS4P is free to everyone, and there is no charge for it.
    Thanks JimmyC
    I simply changed the serial for the one in My Accounts, closed and re-opened Daz and now it has changed from Advanced to Pro.
    Excellent!
    Installed Plugins that don't load
    d3dGenX.dll - I'm assuming this is the Genesis Gen X Plugin which I reset re-installed but it still doesn't load
    infinitoPlugin.DS4.64.dll - I reset re-installed but it still doesn't load
    dzautoriggercontrol.dll - not sure what this does but it doesn't load
    dzmimicrealtime.dll - not sure what this does but it doesn't load
    dzoptitexclothcontrol.dll - not sure what this does but it doesn't load
    Anyone got any answers?
    or is their a page/post that deals with plugins that need updating, don't function etc
    edited August 2012
    GenX and the DSF toolkit are in the process of bing updated by D3D, and should be available soon.
    Infinito has been updated, and there is a link to download the new DLL for it, I will see if I can find it for you.
    Autorigger is installed OK in my version?
    Mimicrealtime is a paid for plugin
    The optitex cloth control comes as part of DS4P, the plugin is the paid for version, if you don;t have that then you should not install it.
    Hope that helps a bit.
    EDIT:
    Here is the link to the Infinto plugin update :http://www.daz3d.com/forums/discussion/5973/
    Post edited by JimmyC_2009 on
  • Zev0Zev0 Posts: 7,121
    Just tested Using Dynamic cloth. The clothing doesn't even load. Is this normal in 4.5? Am I missing something?
    What dynamic clothing item are you using? In general, it works fine for me.
    Lol all of them. Mostly optitex daz freebies. They used to work in 4.5Candidate3 but now they don't.
  • Richard HaseltineRichard Haseltine Posts: 107,945
    If you have the Dynamic Clothing Control plugin you need to reset it to get the update - although DS includes the free base version it won't install it if the control version is present (because if the SDK hasn't changed doing so would force people to reinstall the control plugin when they didn't need to - it's a choice of evils here). Autorigger is part of the Optitex system, so updating the control plugin will update that.
    Mimicrealtime is, I think, the module for Mimic Live! If you own that, reset to get the latest version for DS 4.5.
    same for me - weird
    edited August 2012
    I dont have Dynamic clothing control plugin. They used to load without it with just the basic settings, now not at all. So I must install the updated dynamic control for the base features?
    Post edited by Zev0 on
    No, the control that comes with the download is for the paid for version. Unless you have a serial it wont work.
    I have the paid for plugin, and everything loads and works for me. You should report this as a bug in the Bug Tracker.
    No, if you use only the basic dynamic clothing plugin that should be available. Check Help>About Installed plugins please.
    I just did another fresh re-install of 4.5. I don't even have a dynamic clothing Tab. This is strange.
  • ScoopeyScoopey Posts: 190
    I wish I had not bothered as I loaded the new version And then purchased Gen X to find it was not compatible with it....
    Did not warn me about that on the product page Daz did you?...Still waiting for a refund....
    edited August 2012
    They actually did say Genx wont work. But fear not. The Updated version is coming soon. Its for this reason I keep Daz4.0.3 on my other machine.
    I guess I did not get that memo...certainly was not on the product page
  • RAMWolffRAMWolff Posts: 10,343
    Hmmm, got me curious about plugins... the Dynamic Plugin Controller was included in the Pro version but it's not there in the bundled are of "About Plugins" under Help drop down menu. I see what I guess is an older version further down "dzoptitexclothcontrol.dll" and it failed to load.
    Failed also were:
    dzautoriggercontrol.dll (Auto Rigger Control... is this handled by something else now?)
    dzmimicrealtime.dll ( I guess this is for Mimic but seems old (Version 0.0.0.0) )
    FreeImage.dll (Part of Reality I guess)
    Reality_2.0.dll (Out but not downloaded yet)
    d3dGenX.dll (GenX on it's way)
    I need a solution to this urgently. My entire project has come to a standstill.
  • TheNathanParableTheNathanParable Posts: 1,089
    I guess i'm one of the few lucky people to have not encountered any technical problems yet. I'm not sure if that's because I installed it over the Release Candidate version or not.
    Heck, my only issue is with the implementation of the new features, not anything technical. Methinks this may be another case of Daz being too quick to release something when it's not ready yet.
  • CathyMCathyM Posts: 261
    Hi Zev0 - Just wanted to drop in and say the Basic Dynamic PlugIn SHOULD be working for you - I don't have the Controller version either, just the basic one - last week I installed Daz 4.50.114 over my Daz 4.03 (when it installed, it uninstalled the earlier version.) I still have the tab where I put it on the right side - it's found under Window>Tabs> - its' right under D'Form and above Figure Setup - it shows up in the Installed Plugins list and is green - have you checked these places? I'm having no more than usual trouble with the Dynamic clothes (a little poke thru here and there) - I'm not sure why it's not working for you :down: Hope you can get it figured out. -Cathy
    800 x 500 - 82K
    Not listed under tabs or installed plugins.
  • inquireinquire Posts: 2,421
    edited August 2012
    Well, after all my fears, I upgraded this way (on a Macintosh; Windows may be different): I uninstalled the Genesis Evolution Expressions first of all. Then, I installed the new Genesis Evolution Expressions. Next, I uninstalled the v. 4x Pro with the 4.5 Installer. Lastly, I installed the v. 4.5 of DAZStudio. It's working. I haven't had to uninstall nor reinstall anything else yet. I'm not getting any "Duplicate ID errors," which I'd read about. All of my Content, not only the Genesis stuff, is found. I haven't checked out the plugins yet. I don't see any errors with loading. Oh, yes, the version of 4.5 even came up as 4.5 Pro, without my having to enter a serial number. (Of course, I did have the paid version of 4.x Pro, so I guess 4.5 just picked up that serial number.) Whew! And I was so afraid, after all I'd read, that this would be a monster of a problem. Sometimes, the Mac version of the program causes multiple errors for Mac users, and the Windows people don't seem to understand why the Mac people just can't "get it." Perhaps it's different this time. Is it the Windows version with which people are having problems?
    Post edited by inquire on
