Rogue for V4
wiibbwiibb Posts: 0
I know this might sound like a silly question but I am still new to Daz
I have V4.2 and bought the Rogue for V4 clothes, when I put the clothes on Rogue for V4.2 they do not fit
am I doing something wrong or os V4 different from V4.2?
Thanx
  • frank0314frank0314 Posts: 13,510
    how do you mean it isn't fitting? When you load clothing you need to right click and select "Fit To" and it will fit properly to the figure.
  • wiibbwiibb Posts: 0
    Hi I right click on the clothes and merge into scene and this is what I am getting?
    1366 x 768 - 180K
  • JaderailJaderail Posts: 0
    edited August 2012
    Do not use MERGE select the V4 in your Scene Tab, then do double click on the clothing to load on V4. Then select the Clothing in the Scene Tab open the Parameters Tab and check that the Clothing is FIT TO V4. Fit To is at the bottom of the Parameters Tab. Do this for each peace of the clothing, Fit To.
    Post edited by Jaderail on
    Hi Jaderail, thank you so much for the get Info there and to make my experiance trying to learn Daz that little bit easier with your advice it is really appreciated.
    :P
