Genesis 2 stylized anime options
3dOutlaw3dOutlaw Posts: 2,481
edited May 2015 in The Commons
Are there any Genesis 2 Anime options, similar to the Stylized A4/A3 (i.e. with bigger eyes and no nostrils, sharper chin, etc...) like the attached. I don't see any in promos or descriptions, but I may have missed them.
Post edited by 3dOutlaw on
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,250
    edited May 2015
    Have a look at http://www.daz3d.com/keiko-6 or http://www.daz3d.com/callie-6 or http://www.daz3d.com/the-girl-6
    They all have anime influenced styles. The image is Keiko 6.
    1000 x 1300 - 167K
    Post edited by Design Anvil - Razor42 on
  • BeeMKayBeeMKay Posts: 7,019
    There's also this: http://www.daz3d.com/animated-shapes-for-genesis-2-male-s
    but it's males only.
    edited May 2015
    None of them have a no-nostril option that I found. Keiko is in my wishlist, but to be honest, I have gotten real close to that using morph options.
    The Animated versions of the male are real good! I was wondering if The Six was going to make a female version?
  • DiomedeDiomede Posts: 15,437
    You might also consider
    - legacy shapes for G2F includes Aiko 4
    http://www.daz3d.com/generation-4-legacy-shapes-for-genesis-2-female
    - the Cassie 6 and Aiko 6 characters are toon figures
    If these don't work separately, you might combine/mix them to get what you want.
    Thanks! The Aiko4 shapes was an interesting idea, but I don't see that it has the Stylized morph in the doco or filelist.
    The others are Toon figures, but I am not looking for a general toon figure.
    I guess it hasn't been done (yet?).
  • riftwitchriftwitch Posts: 1,439
    You could always convert the older morphs with GenX. I've had good luck with Generation 3 and 4 figures.
    edited May 2015
    That's true, but I missed my window on GenX for a cheap upgrade, so I don't have the latest support for G2F :(
    Instead, I I just spent 20 minutes in Hex, with Dolly and the Soften tool, and found it is pretty easy to "pull out" the nostrils and flatten them.
    That works for me, as I can save them back as a morph via the bridge.
    So I may end up getting Keiko at some point. Maybe today if I can stack 3 coupons ;-)
    EDIT: NM, apparently you can’t stack coupons. You can only use one coupon at a time...
    You could convert older morphs with GenX. I've had good luck converting generation 3 and 4 figures to Genesis and Genesis 2.
    Never mind; somehow I got a double post.
