Any other outfits for Kaida(v4)?
Upirium
I didn't actually realize Kaida was also for genesis, but I'm using her with V4.
Are there any other outfits that work with V4 that are for Kaida?
The product here is this:
http://www.renderosity.com/mod/bcs/sase-kaida-v4-and-genesis/94995
Obviously Dany
I know there's Fire Princess and Dragon Lady Outfit (and hair), and I think one for genesis but like I said, I'd rather it be for V4...
I assume you mean outfits that fit the GOT inspired theme the character is portraying since any V4 outfit will work.
Are you looking for actual outfits inspired by GoT, because if not, any fantasy style clothing will work. While inspired by 300, SAV's Electra Outfit, also at Rendo, fits the bill (funny enough played by Lena Heady who's also in GoT).
Well yeah I mean typcially GoT outfits
I also found Desert Queen but I would like Dany to have some variety
I'll look at the electra outfit though
You will see a number of character sets that are listed for V4 and Genesis. By default, Genesis uses V4's uv map. IIRC, the Genesis figure lacked some mapping in the eye which was corrected in G2F. Morphs are another story. If the morph is for V4, out of the box you would need the Morphs++ pack. If it was for Genesis, you needed the Evolution Morph packs (head and body). If you didn't or don't own the Evolution morphs for Genesis, you can still use the texture on Genesis but it won't look the same.
If you want to use clothing designed for V4 on Genesis you can use the auto fit function that is part of DS or you can purchase the V4 and Genesis add on products for Wardrobe Wizard and go that route. Or you can try the fitting room in Pro 2014.
