whole room disappearing in iray preview
if anyone has any iea what could be causing this that would be great,
it happens in both camera and perspective view
thanks
  • SofaCitizenSofaCitizen Posts: 2,183
    When you select those elements and go to the Display section in the Parameters tab is "Visible in Render" switched on?
  • VicSVicS Posts: 1,273
    edited May 2023
    I turned it off for the emisive shperes, must have done the whole building by mistake ill check that out when I get it opened again, thanks
    oh im supposed to use iray visible to primary rays switched off
    Post edited by VicS on
