whole room disappearing in iray preview
VicS
if anyone has any iea what could be causing this that would be great,
it happens in both camera and perspective view
thanks
When you select those elements and go to the Display section in the Parameters tab is "Visible in Render" switched on?
I turned it off for the emisive shperes, must have done the whole building by mistake ill check that out when I get it opened again, thanks
oh im supposed to use iray visible to primary rays switched off
