How to make a real brow squeeze on genesis 8 and 8.1?
James
I want like the wrinkles beteween the forehead really appear.
There isn't enought base geometry to make wrinkles.
And only PAs can create HD morphs.
You can look for if there is a product that supports that, or you could make a normal map, that gives that impression.
Now, important disclaimer: I'm not a professional sculpter but rather a (very) enthusiastic artist.
Having that out of the way: @Felis : I'm not too sure I agree with your base geometry comment, but I cannot rule out the option that I'm overlooking something.
As mentioned I'm not an avid sculpter (getting better though) and this morph itself took me a while to "perfect" (and it's still quite the hack) but if you look at the result... I think that if I shorten it (maybe break it up in 2 sets?), maybe increase the Z intensity just a little bit more?... then this should be doable. ... or so I believe.
For the record: yes, I somewhat "cheated" by sub-dividing the mesh in ZBrush and you shouldn't focus on that wrt the geometry, but still, there is room to wrinkle parts of the forehead. ... or so I think.
the wrinkles that I envision are between the brows, though not on the forehead..
You may try to use some expression morphs from Daz.com, for instance: Compression HD + Brow Squeeze, uncheck Use Limits and increase the values a litttle bit. Then, use GoZ or blender etc. to make some crease in between the inner brows then import as a delta morph, so as to make some subtle change. (I made one with blender...) You even can mix the expression with other brows related morphs and create a unique single dial.
PS: Normally we won't separately bake normal or displacement maps for expressions, but you can do it if you'd like...
I'm going to take on this "challenge". No promises (!), as I mentioned this hack already took me some time, but I see opportunities for me to learn new stuff. ... no to mention that I found the most awesome Z brush to make this work (SO much pun intended!). I'll get back at most upcoming Monday but please: don't get your hopes up and don't expect results. But I am going to give this a solid attempt.
Secret little bird told me I can probably even share morph files as an attachment here so... yah ;)
