How to make a real brow squeeze on genesis 8 and 8.1?
I want like the wrinkles beteween the forehead really appear.
  • felisfelis Posts: 6,503
    There isn't enought base geometry to make wrinkles.
    And only PAs can create HD morphs.
    You can look for if there is a product that supports that, or you could make a normal map, that gives that impression.
  • ShelLuserShelLuser Posts: 749
    Now, important disclaimer: I'm not a professional sculpter but rather a (very) enthusiastic artist.
    Having that out of the way: @Felis : I'm not too sure I agree with your base geometry comment, but I cannot rule out the option that I'm overlooking something.
    As mentioned I'm not an avid sculpter (getting better though) and this morph itself took me a while to "perfect" (and it's still quite the hack) but if you look at the result... I think that if I shorten it (maybe break it up in 2 sets?), maybe increase the Z intensity just a little bit more?... then this should be doable.  ... or so I believe.
    For the record: yes, I somewhat "cheated" by sub-dividing the mesh in ZBrush and you shouldn't focus on that wrt the geometry, but still, there is room to wrinkle parts of the forehead.   ... or so I think.
    1920 x 1040 - 246K
    1920 x 1080 - 270K
  • JamesJames Posts: 1,190
    the wrinkles that I envision are between the brows, though not on the forehead..
  • crosswindcrosswind Posts: 10,249
    edited May 2023
    You may try to use some expression morphs from Daz.com, for instance: Compression HD + Brow Squeeze, uncheck Use Limits and increase the values a litttle bit. Then, use GoZ or blender etc. to make some crease in between the inner brows then import as a delta morph, so as to make some subtle change. (I made one with blender...) You even can mix the expression with other brows related morphs and create a unique single dial.
    PS: Normally we won't separately bake normal or displacement maps for expressions, but you can do it if you'd like...
    1560 x 1393 - 1009K
    Post edited by crosswind on
    I'm going to take on this "challenge". No promises (!), as I mentioned this hack already took me some time, but I see opportunities for me to learn new stuff. ... no to mention that I found the most awesome Z brush to make this work (SO much pun intended!). I'll get back at most upcoming Monday but please: don't get your hopes up and don't expect results. But I am going to give this a solid attempt.
    Secret little bird told me I can probably even share morph files as an attachment here so... yah ;)
