Animal lovers: Bear Cubs released [Commercial]
2»
  • SorelSorel Posts: 1,437
    edited May 2015
    Hello Alessandro. I have finally got around to rendering one of the cubs. They sure give my system a workout lol. This is rendered in octane. There is some sss for the body texture, then tweaked an octane hair shader to get it white. The environment is the Winter Terrains with a snow shader. Took about an hour and a half with 2000 samples. Only used one of my cards so I could do other things while it rendered lol.
    1920 x 1080 - 2M
    Post edited by Sorel on
  • Alessandro MastronardiAlessandro Mastronardi Posts: 2,659
    Great render Sorel, I can imagine how massive the process must have been: the bear cubs have a lot of fur so I believe you probably ended up with a 2-3GB OBJ file. Brilliant result!
  • PhiloppPhilopp Posts: 294
    Thank you very much Alessandro_AM for the really nice figures
    2000 x 1500 - 1M
    edited May 2015
    Wow, very beautiful, is this rendered in DAZ Studio? And thanks to you and all the nice folks around here for supporting my products.
    Post edited by Alessandro Mastronardi on
    Yes, it is a render with 3DLight in DAZ Studio. I used Ocean Wide and the Ground Shader for DAZ Studio (Ice and Snow).
  • alexhcowleyalexhcowley Posts: 2,409
    Alessandro,
    More temple frolics. This is wonderful pose, the bear looks adorable from almost any angle.
    Cheers,
    Alex.
    2000 x 1250 - 445K
  • FishtalesFishtales Posts: 6,233
    I've used a few of your animals but have taken them over to Bryce :-)
    I used the bear cubs in this one.
    Holiday Bears
    1000 x 556 - 431K
    Holiday Bears
    Lovely render, the cubs look really happy there!
  • RedzRedz Posts: 1,459
    edited June 2015
    First attempt at rendering the black bear cub in iray :)
    My poor little system couldn't handle the full hair count so I had to adjust that. (used 300000, 500 root and 200 tip)
    converting to obj took a couple of minutes, and the iray render was fast (under 10 minutes on my modest laptop)
    Getting the shaders right took more time and I know I could do better.
    For the eyes I used the iray thin water shader, and made some adjustments to the fur.
    The claws need work as they look too bright right now.
    Such a cute little bear. Thank you Alex
    1200 x 1200 - 825K
    Post edited by Redz on
