the production frame won't let me select it?
MistaraMistara Posts: 38,675
i've never had this problem before.
trying to reposition the production but it won't let me grab it, the cursor doesn't change.
what can i do?
Thanks.
  • DiomedeDiomede Posts: 15,452
    Not sure, but you might check to see if your production frame ratio is locked in the render room. That is, where you put in the dimensions for the render output, check to see if the checkbox for keeping the ratio is checked.
    i tried it checked and unchecked. normally i grab the handles at the corner to resize the thing. gonna give it a reboot.
    Do you have the camera selected in the instances tab?
    What Tim said! Make sure the camera is selected.
