Adding to Cart…
yes to all the above
C8.5.0.149
DS4.5.0.90
for Genesis the exported pz2 files I have saved can be loaded by alternatively browsing to the folder it is in and adding it to content as Poser content even if in documents or pictures etc.
you then just load them on the selected figure without limits
Well I downloaded and installed the release of studio 4.5. Still opens to my windows tool tray and not the desk top. No big surprise there.
The big surprise is my aniblocks are gone, poof, deleted from their folder. No where to be found.
Thanks DAZ, you are a big help in this >:-(
Starting a thread on this in the studio forum.
Did you install the Genesis Starter Essentials?
And here we go with the logging back in every 15 minutes.
All I got was the studio 4.5 release, there was so much there I wasn't sure what else to down load. but how; or more to the point why, would that have deleted my aniblocks?
As has always been the case, installing DS 4.5 uninstalls the default content from DS 4.0. The default content is now in a separate installer, Genesis Starter Essentials.
Downloading, but I don't see where stuff for genesis would effect my already installed content.
I also see I have a ton of V4/M4 updates for carrara, guess I'll download them while I'm at it.
It only removes content which was installed by the previous version.
http://www.daz3d.com/forums/discussion/6315/ see me there.
1- yes
2- don't use .pz2 - so never tryed it - just use .duf
3- yes - Genesis - V4 with dynamic clothing and conforming
C 8.5 pro
DS 4.5.0.114
Yes, pz2 has worked; I'd have to check to be sure it still does, never know with DAZ.
Thanks for the info - I see Wendy is using DS RC3 and the previous Carrara Beta, while bigh, like me, is using the latest of both. You are both probably n Win 7, 64bit?
I'm on XP 32 bit - that may be the difference.
I can import .duf scenes and stationary figures, as well as stationary .pz2 files, but when anything is baked, it fails for me - baking involves making morphs and that seems to be the problem. In my version of Carrara, Genesis morphs, apart from the body shaping ones, don't work at all. So there may be some connection.
For instance, C172 won't import an animated .pz2 made in Poser, but 149 does.
Will just have to leave it for Pierre to do his magic - it's no big deal for me as my only use for DS is to do rigging, which works just great. Would like to get dynamic clothes working, but that's just because I like things to work.
yes Win7 64bit but I use the 32bit of DS4.5 for lipsync and that imports into Carrara too although I have the Mimic plugin anyway.
the latest Carrara will not do facial expressions or mimic for me so that is why I dropped back a build.
yes - win 7 , 64bit
so you can not do any morphs in C - I can do what I want just like DS - except DY. cloth - every thing else work just the same
so let keep going - using DS 4.5.0.114
clear the scene - Genesis went on a trip
now load a new V4 ( not some thing from the past ) - plan jane - no nothing with purple
now load your Dy. cloth
now drape it no animation - did it work - yes - freeze - save it as scene DUF
clear scene - open it - works - good
now clear scene - load new V4
load Dy. cloth - drape - now start timeline - goto frame 30 - move V4 arms down to side
go back to frame 0 - drape animation - run - if you like it freeze it - save as scene Duf
clear scene - load the animation back
is it ok
now do same thing using say V4 she freak
is it ok
moving on to C .
now in C 8.5 make new medium scene
import the first file from DS
is it ok
if it worked
try the animation
if they work try V4 she freak
@Wendy - only the Genesis morphs are bust in C172 - Daz-Spooky and others mentioned the same problem, but apparently not as severe as mine. I'm reverting to C149 - don't see what improvements have ben brought in on C176.
@bigh - the cloth sims work great in DS - I can save as .duf and reload into DS, no problem. Getting into Carrara as an animation is where it all goes south - getting a single frame drape on a T-posed figure, no problem.
ok guess you will have to wait for next beta
