She hulk render issue. What is it? Why is it? and how can I fix it?
RKane_1
She hulk render issue. What is it? Why is it? and how can I fix it?If it helps, I am using DAZ Studio 4.7 still and the map is for Victoria 4 but using Genesis and I made sure the texture map knows that. :)
Post edited by RKane_1 on
It might be an issue with the scene lighting when it hits the mid rift.
Check reflection in case it is cranked up to far.
and check for a reflection map in the figure, also you may want to check specular settings.
is she on vacation? I thought she was an attorney.
Stratdragon,
The girl is allowed a break from time to time. :)
Huh.... if either the displacement map or bump map is on even by a small percentage, it does that. And I tried different maps, too. Any will do it.
I guess maybe my morph in that area was too extreme?
If you were curious. :)
