She hulk render issue. What is it? Why is it? and how can I fix it?
RKane_1RKane_1 Posts: 3,039
edited May 2015 in Daz Studio Discussion
She hulk render issue. What is it? Why is it? and how can I fix it?If it helps, I am using DAZ Studio 4.7 still and the map is for Victoria 4 but using Genesis and I made sure the texture map knows that. :)
Post edited by RKane_1 on
  • Zap ZZap Z Posts: 60
    It might be an issue with the scene lighting when it hits the mid rift.
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,250
    Check reflection in case it is cranked up to far.
  • StratDragonStratDragon Posts: 3,290
    edited May 2015
    and check for a reflection map in the figure, also you may want to check specular settings.
    is she on vacation? I thought she was an attorney.
    Post edited by StratDragon on
  • RKane_1RKane_1 Posts: 3,039
    Stratdragon,
    The girl is allowed a break from time to time. :)
    Huh.... if either the displacement map or bump map is on even by a small percentage, it does that. And I tried different maps, too. Any will do it.
    I guess maybe my morph in that area was too extreme?
    If you were curious. :)
    720 x 1080 - 606K
