Genesis 2 Female Mat issue
LeggyBlond
When copying the 'Hip' Mat from G2F and pasting it too the 'Hip' mat for G2F genitals it very often does not match. It seems the G2F Gens are not at present able to carry the same amount of parameters. Spending lots of time adjusting the xisting paramters as best as possible to match is real pain.
if anyone has an answer to overcome this issue I would like to know.
You need to apply the base shader first, that isn't copied and pasted since it isn't a setting.
Sorry to be a pain but although I use shaders, I'm not exactly sure what you mean by a 'Base Shader'. I found various shaders call 'Base' in my Uber and Omnifreaker shader folders but they don't solve the issue.
Where do I find the appropriate base shader?
Barbara
admin said,," base shader" means, which you used for your character hip.
then to make it easy, you just need to apply same mat preset which you used for your Actor,
with select anatomy.
then the base shader applied to the anatomy. after that, you can copy and paste
shader property value from hip to the anatomy surfaces.
(female is easy to apply skin, same uv of hip can be used
about man I understand,, it is difficult ,without set which have alrady the anatomy material.
I can not apply clean anatomy texture for my man monstor actors,,><;<br /> need to make by myself,,)
Oh silly me...got it and thank you.
Barbara
