obj is deformed in daz but looks fine in blender or 3ds
VicSVicS Posts: 1,273
edited April 2023 in Daz Studio Discussion
the third image is the shoe in 3ds where it looks fine-there are my import options
does anyone have any idea what may be causing this to heppen?
I did restart daz and reimport but same problems
Post edited by VicS on
  • UncannyValetUncannyValet Posts: 276
    edited April 2023
    Looks quite similar to me but the sole and heel itself are missing?  The missing parts may just have zero opacity?
    Perhaps if opacity is not the issue, as a quick solution you can just export the Blender one as obj, if it looks fine, and then import that version into Daz.
    Sometimes it is best to import obj while unchecking the "read material library" option as the associated .mtl file may introduce some unwanted Shader settings, such as opacity changes, diffuse overlay, etc. It may also assign maps to incorrect shader paramaters.
    Post edited by UncannyValet on
  • PadonePadone Posts: 4,336
    If you used ngons then daz studio has a limited support so you need to triangulate or convert to quads.
  • Cris PalominoCris Palomino Posts: 12,986
    And ngons is not a good thing to have for final models.
  • VicSVicS Posts: 1,273
    edited April 2023
    file does not have  ngons
    here's what it looks like with evrything visible
    the file was never doing this before,  its happening in the updated versions
    2365 x 1481 - 2M
