Crashing During ERC Freeze
JimdaJimda Posts: 3
Has anyone else had trouble with DAZ crashing when using ERC Freeze?
I've been having issues with it for about a month. Early on it would crash, then I could try again and it would work. Now, though, it crashes every time. At first I thought it may have been a memory issue (that I hadn't allocated enough to DAZ), but I've since assigned more and it hasn't helped. I have a feeling the issue is on my end because both 4.7 and the 4.8 Beta crash, but I thought I'd ask here, just in case.
    That's not typical. I use ERC freeze very regularly without crashes in both 4.7 and the 4.8 beta. Old versions of the program had it much less stable, but that's going back to 4.0 or so.
  • JimdaJimda Posts: 3
    Yeah, that's what I thought. I've used it quite a few times in the past without issue. Think I'm just freaking out a bit because I have a ton of products basically finished all except the morphs and I can't submit them until I can get ERC to work again. Knowing it's on my end narrows it down, at least.
