I need some info about the NA vs N/A codes for products on store product pages
I want to know if the following product is useable in Daz 4.7 I have passed on several products because they have these codes and I think/thought they were incompatable in 4.7 I'm also in need of some facts about the Auto-follow / AutoFit tools and which I would use to put genesis products on Genesis 2 figures
The textures in the attachments are my main concern at this time.
Thank you for any info: Aidan stone
This particular product only contains texture files, as it says. JPG files which are tileable, meaning that they can be used to generate a shader. or a texture set for another product.
Here is some info about auto-fit in case it might be helpful:
https://helpdaz.zendesk.com/entries/20680798-Converting-Generation-4-Content-for-use-with-Genesis
And here is a video explaining how to use the Surfaces pane, which is where you could manually apply one of the seamless textures to an item:
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/surfaces/videos/surfaces/start
For future reference, when the product description in the upper right of the product page lists compatible software and compatible products, those are to identify dependencies or requirements necessary to use the product. In the case of the textures, these categories say "No" and "No", indicating there are no specific3D programs required for their use and no other products are required for their use. In the example product, tileable textures like these could be used to create textures for any model useable in any 3D program. Conversely, a texture created specifically for a garment designed for Genesis 2 Female with shader settings for use in DAZ Studio would list the original garment under compatible products and DAZ Studio under compatible programs.
