Carrara freebie/sale render and discussion thread
124
  • Bunyip02Bunyip02 Posts: 9,278
    edited March 2023
    https://www.daz3d.com/dp-daz-dragon-3-carrara-shaders
    Somethings up with the division of the Shader on the wing, will investigate further.
    https://www.daz3d.com/gated-courtyard
    Tried Sparrowhawke's UV Unwrap on this one for the back/side walls and the grounds - no result. Will replace with another shader.
    https://www.daz3d.com/asian-prop-set
    Replaced the blades shader with a chrome, and adjusted the Outer Glass Lantern shaders to fully transperant.
    1600 x 1200 - 5M
    Post edited by Bunyip02 on
    edited March 2023
    Works fine, problem of two toned wing was caused by a spotlight that I added to the scene to lighten the underside of the wings. Note to self, don't rush the lighting !!!
    Ground is fine, the exterior walls are stretching the UVs
    Trial 1 Shader still stretching
    Trial 2 Shader - that's more like it !
    2751 x 1028 - 621K
    2272 x 1033 - 2M
    3226 x 1032 - 2M
    2831 x 1035 - 2M
    edited March 2023
    1600 x 1200 - 3M
    edited March 2023
    https://www.daz3d.com/maki-outfit-looks
    Had a number of "An error has occurred" results with this one before it worked.
    https://www.daz3d.com/50-lips-for-genesis
    1600 x 1200 - 4M
    edited March 2023
    1600 x 1200 - 5M
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,303
    most of those I don't own the clothes crying
    I just add them to my growing wishlist of clothes I have extra textures for
  • DiomedeDiomede Posts: 15,398
    edited March 2023
    From orc sales.  This is Grammock for G9.  I added some green in subsurface scattering and I think that took out some of the skin detail.  Really notice the difference because of the lack of support for Daz's particular HD in default Carrara.  I think I would construct and mix in a skin shader with more roughness next time.  Problem is, because G9 reduces the number of skin material zones, it is a pain to exclude lips, etc.
    1309 x 1600 - 207K
    Post edited by Diomede on
    I have quite a few of them, mostly bought on sales.
    Looking good !!!
    Have you tried Philemo's HD Plugin with this model ? https://www.daz3d.com/forums/discussion/302941/any-news-on-the-hd-plugin-d/p2
    edited March 2023
    https://www.daz3d.com/krugan-the-orc-hd-for-genesis-9
    Used Philemo's HD plugin on this beastie !
    1600 x 1200 - 5M
    edited March 2023
    Well done, Bunyip02.  Your skill in applying the plugin yeilds much better skin detail for your G9 Krugan orc than the G9 Grammock I tried.  yes
    Thanks, but it's Philemo's skill in the HD plugin that gets the results - I just follow the steps !!!
  • StezzaStezza Posts: 8,819
    edited April 2023
    laugh
    800 x 600 - 305K
    Post edited by Stezza on
    edited April 2023
    https://www.daz3d.com/noir-outfit-for-genesis-2-female-s
    The Clothes have a setting in the Reflection channel in the shaders.
    Dress with Reflection set to none.
    1600 x 1200 - 4M
    2277 x 1035 - 1M
    edited April 2023
    1600 x 1200 - 2M
    edited April 2023
    1600 x 1200 - 5M
    edited April 2023
    https://www.daz3d.com/tyrnea-raheal-for-royal-elf
    https://www.daz3d.com/deadend-poses
    Note - some of the poses caused issues with the Royal Elf clothes
    1600 x 1200 - 2M
    edited April 2023
    https://www.daz3d.com/men-s-night-life-textures
    Glossy textures - setting in the Reflection Channel shaders
    1600 x 1200 - 2M
    2278 x 1036 - 914K
    edited April 2023
    1600 x 1200 - 1M
    edited April 2023
    https://www.daz3d.com/caput-caseum-textures
    dsa format - needs to be saved as duf material presets
    1600 x 1200 - 2M
    edited April 2023
    https://www.daz3d.com/aneta-for-victoria-6
    Problem with the MAT pose - is AoA shaders all black - added texture maps manually
    https://www.daz3d.com/ninja-chan-for-genesis-2-female-s
    1600 x 1200 - 2M
    3835 x 1038 - 554K
    edited April 2023
    https://www.daz3d.com/nitro-dress-textures
    https://www.daz3d.com/gentleman-adventurer-poses-for-d5
    https://www.daz3d.com/bus-rex
    Bus came in large compared to Genesis, could do with being scaled down. Also replaced the Chrome texture with a Chrome shader from the Shader library.
    Bus at 100% size
    Bus at 70% size
    1600 x 1200 - 2M
    1600 x 1200 - 2M
    edited April 2023
    1600 x 1200 - 4M
    edited April 2023
    1600 x 1200 - 551K
    edited April 2023
    https://www.daz3d.com/desiree-for-victoria-7
    https://www.daz3d.com/honey-bun-pose-expression-bundle-for-girl-7
    Problem with the Poses distorting the back of the head/neck/shoulders in Carrara
    Tried a few different poses as well as the Girl 7 morph, issue affecting all
    All okay in DAZ Studio
    Render from front on
    3842 x 3095 - 2M
    2423 x 1031 - 484K
    1600 x 1200 - 3M
    edited April 2023
    Easter Eggs Hair & Bikini
    1600 x 1200 - 2M
    edited April 2023
    Easter Egg DD PBR Metal Grille Shaders for Iray Vol 2
    Workaround added
    Render with 2 planes shaders changed to metal grille
    Step A - Used Paint.net. Open Grille texture. Click on Adjustments Tab, then click on Invert Colors
    Step B - Staying in the Adjustments Tab, click on Black and Alpha+
    Step C - Still in the Adjustments Tab, click on Invert Colors again
    Step D - Save as something different that will identify the change
    Step E - Update the shader in Carrara, requires Philemo's PBR Lighting - https://www.daz3d.com/forums/discussion/comment/4625561/#Comment_4625561
    1. Top Shader, click on Lighting models, select PBR Lighting model
    2. Color, click on Operators, select Multiply
    3. Color - Source 1, select  a colour from the DD PBR Metal Grille Shaders for Iray Vol 2 textures
    4. Color - Source 2, select the modified Grille texture that you altered in Paint.net
    5. Metallic - needs further investigation
    EDIT:- instead of following the Step 2 you can also add the Colour Metal texture to the Color channel & add the Grille texture to the Alpha channel, is easier.
    Had this sorted but took a break, and wrote down the steps after a couple of hours away - should have done it at the time !!!!
    1600 x 900 - 1M
    1523 x 881 - 140K
    1530 x 871 - 143K
    1531 x 876 - 161K
    1525 x 887 - 215K
    2273 x 1033 - 470K
    edited April 2023
    Shader Woes - Reason for Steps A to D
    Found out that the Triplanar method for resizing textures does not work in the Alpha Channel. Note Shader ball has no Grille openings.
    Resized 2048 pixel size texture to 512 pixels for next step.
    In a program called Swatch-Maker by Winterbrose converted 512 pixel texture to 4096 pixel texture.
    In Carrara tried loading the 4096 pixel texture into the Alpha channel, got an open error.
    Hence steps A to D which was accepted by Carrara, and also reduced the texture size from 48MB to 1.16MB.
    Another option is to resize the 4096 pixel texture to 2048 pixel texture.
    No joy on remembering the steps to get a metal looking grille. When I went to sleep last night was counting shader options instead of sheep !!!
    2268 x 1043 - 382K
    1523 x 828 - 112K
    1921 x 1043 - 79K
    2268 x 1030 - 357K
    2263 x 1040 - 1M
    edited April 2023
    Doing a bit of experimenting with Metalness
    2271 x 1030 - 2M
    2276 x 1040 - 2M
    edited August 2024
    Sexy Librarian for Genesis 2 Female(s) - https://www.daz3d.com/sexy-librarian-for-genesis-2-female-s
    Glasses - caused Carrara to hang needing to CTRL-Alt-Delete out. Saved as a scene subset in DAZ Studio after which they loaded okay.
    Shoes not included.
    1600 x 1200 - 4M
