Grass, leaves and stones in Daz (instancing multiple items)
I should have asked this yesterday, but what's the easiest way to place grass or other items over an existing terrain in daz? I tried the node instancing, but that takes forever as you have to manually place every strand.
Yesterday I spent hours exporting everything to blender, then using their particle system to cover the ground and then importing it back to Daz, reorienting and aligning everything, fixing the surfaces, waiting for everything as my pc chugs along, rinse and repeat until I achieved the look I wanted. I now want to add leaves and some weeds and stuff, but I'm really not looking forward to going through that long process again.
Post edited by BradCarsten on
There are various options, like
- http://www.daz3d.com/grass-shader-for-daz-studio (alternately: http://www.daz3d.com/rock-grass-bundle)
- http://www.daz3d.com/pred-pack-grass-one
- http://www.daz3d.com/grassy-grounds-megapack
If you give your ground various material zones, you can mix various styles of grass.
Alternately, you can try growing grass using
- http://www.daz3d.com/garibaldi-express-hair-system-for-daz-studio
or
- http://www.daz3d.com/look-at-my-hair
Thanks lee_lhs. Sorry, I wasn't all that clear, and have rephrased the question. What I'm really wondering is how to place multiple items- like strands of grass, or leaves, or a thousand stones across their scene.
That said some of those links are really interesting- especially the hair system. - I didn't even know that existed, but I can see how useful it can be, so thanks for that.
There is a free "eco system" script in sharecg (lost the link)
You can use send in the closes, or you can just use instances of groups of objects.
Oh, that's easy.
You can either use this product:
- http://www.daz3d.com/send-in-the-clones-ds4-pro
There's a free script:
- http://www.daz3d.com/forums/viewreply/710470/
Or do it manually, by selecting the item you want to multiply, go to "Create" and then select "create new node instance".
Also:
* http://www.daz3d.com/forums/viewreply/479852/
I actually tried that yesterday, but couldn't get it to work properly. I would clone 1000 instances and only 10 would show up or something. I don't know if it was a bug or (and more likely) I was doing something stupid but I must play around with it again, because that would be perfect. You can even use density maps, which is awesome.
That looks pretty interesting- and it's on sale at the moment..... Hmmmm
The thing to watch with Send in the Clones is stated on the Product Page:
There is no memory saving like using the Node Instance in DAZ Studio.
That's true. The replicator script would probably be better then, if I can get it to work. Yesterday I had to convert instances back to geometry, and daz crashed a number of times on me.
Here's the Send in the Clones Manual,
http://docs.daz3d.com/lib/exe/fetch.php/public/read_me/index/15235/15235_sendintheclonesds4pro.pdf
It's pretty useful for some stuff.
oooh, thats hugely helpful. I always try to watch a tutorial before buying anything so that I know exactly what I am getting and what its features or limitations are.
You can find readmes and such for most of the newer products here:
http://docs.daz3d.com/doku.php/public/read_me/index/start
Just check the Product ID against the list at the left side.
