Need help in animate with clothing.
Someone may have asked this before but I am starting to learn how to animate finally, but when the character walks it looks like the clothes are disappearing or something. How do I fix that, thank you so very much. I have been searching but I am not sure what to call it.
There used to be a small plugin called "POKE AWAY" on the store. Check out.
thank you I will do that. Have a great day
Make the body parts that poke through invisible.
Under edit geometry add a smoothing modifier to the clothing, clothes on top of other clothes can be set to collide with those instead of your figure.
you can also add a geometry shell to the figure and give it an offset in parameters then make that the collision item for the clothing.
