Need help in animate with clothing.
ShoniahagoodpoliteShoniahagoodpolite Posts: 10
edited December 1969 in Art Studio
Someone may have asked this before but I am starting to learn how to animate finally, but when the character walks it looks like the clothes are disappearing or something. How do I fix that, thank you so very much. I have been searching but I am not sure what to call it.
1600 x 900 - 198K
  • digitalcraftdigitalcraft Posts: 57
    There used to be a small plugin called "POKE AWAY" on the store. Check out.
  • ShoniahagoodpoliteShoniahagoodpolite Posts: 10
    thank you I will do that. Have a great day
  • UVDanUVDan Posts: 112
    Make the body parts that poke through invisible.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,835
    Under edit geometry add a smoothing modifier to the clothing, clothes on top of other clothes can be set to collide with those instead of your figure.
    you can also add a geometry shell to the figure and give it an offset in parameters then make that the collision item for the clothing.
