Polygon count and why did the mesh change?
SylvanSylvan Posts: 2,719
edited December 1969 in Hexagon Discussion
I started on assigning material zones to my object but I see the polygons changed!
Can anyone explain this to me why this is happening?
Also I am curious if there are guidelines to polygon counts in objects for Poser and/or DS.
Image 1: this looks acceptable
Image 2: oops, what happened?!
  • 3WC3WC Posts: 1,145
    Looks like everything got subdivided. Is that Daz Studio?
  • SylvanSylvan Posts: 2,719
    Hexagon. It sometimes changes without warning.
    I can't figure out how! And how do I get it back to lowpoly again ><</p>
  • ncampncamp Posts: 345
    Long time since I used hex, but it looks like you smoothed the objects.
    Yes indeed!
    And once you used a higher smoothing setting, it won't remove the access ones even though you lower the setting :(
  • RoygeeRoygee Posts: 2,247
    Once you collapse DG, that's it - you are committed. You can get back to the lower poly by undoing, but once it's saved, it's permanent.
    Smoothing is the very last thing I do, then I save that as a different version in case I want to go back to the unsmoothed version.
    A wise advise.
    It's something I'll take with me in my future endeavours!
    And I'll also make sure to save an unsmoothed version from now on...
    Learned at the school of hard knocks!
    Also a good idea to save as .obj as well - just in case the file gets corrupted, you can get it back in any other app that imports .obj :)
    Will do :D
