Aspect Ratio in Render Settings Pane
The aspect ratio settings in the Render Settings pane only go to three decimal points. Is there any way to increase that?
Thanks.
  • Richard HaseltineRichard Haseltine Posts: 108,949
    Aspect ratio is proportion, not absolute size - what values are you needing to enter?
  • leo04leo04 Posts: 394
    I am creating a graphic novel and am working in CorelDraw. When I add a image to the page I have a box of a specific size and want to use the dimensions that box uses.
    As an example I would like my W=4.0625 and H=4.2221.
    I input these factors into the fields and get W=4.060 and H=4.222.
    I am a bit of an accuracy nerd I guess.
    Thanks.
    Just turn off constraints and then enter the size - even if the aspect is rounded you should still get the right size of image.
  • chris-2599934chris-2599934 Posts: 1,915
    Try W=406.25 H=422.22 (i.e. multiplying both your original figures by 100). That will give you the same ratio without rounding or overflowing either number.
