Aspect Ratio in Render Settings Pane
leo04
The aspect ratio settings in the Render Settings pane only go to three decimal points. Is there any way to increase that?
Thanks.
leo04
Thanks.
Aspect ratio is proportion, not absolute size - what values are you needing to enter?
I am creating a graphic novel and am working in CorelDraw. When I add a image to the page I have a box of a specific size and want to use the dimensions that box uses.
As an example I would like my W=4.0625 and H=4.2221.
I input these factors into the fields and get W=4.060 and H=4.222.
I am a bit of an accuracy nerd I guess.
Thanks.
Just turn off constraints and then enter the size - even if the aspect is rounded you should still get the right size of image.
Try W=406.25 H=422.22 (i.e. multiplying both your original figures by 100). That will give you the same ratio without rounding or overflowing either number.
