Adding to Cart…
https://www.daz3d.com/real-feel-pullover-genesis
https://www.daz3d.com/colors-for-elements-hair
https://www.daz3d.com/boots-for-genesis
https://www.daz3d.com/a-gentleman-s-wardrobe-for-michael-6
https://www.daz3d.com/erynion-for-elven-warrior
Getting "An Error has occurred" messages with several clothing items, anyone else having any issues ?
Yup, same Error message
The jacket loads OK from the Suit. Didn't bother with the elven warrior
Thanks for confirming !
Boots not shown as getting "An error has occurred" message when opening in Carrara.
https://www.daz3d.com/ashleigh-jumpsuit-for-genesis-2-female-s
https://www.daz3d.com/colors-for-tangerine-hair
https://www.daz3d.com/antoinette-dress-for-genesis-2-female-s
https://www.daz3d.com/mila-dress-for-genesis-2-female-s
https://www.daz3d.com/beautiful-monsters-dolly-girl
https://www.daz3d.com/summer-time-textures
NOTE - dsa files, need saving as a Material Preset in DAZ Studio to be able to use them in Carrara (either that or manually load the texture maps)
@Bunyip - looking great. I am enjoying your renders even if I don't comment often. RE: current sales/freebies. So far, I have not done much with March Madness. Hoping for some sales that more closely align with my interests before the end of the month. Keep up the good work.
same
Thanks !!!
Thanks !!!
https://www.daz3d.com/kim-for-lee-6
Had some issues with this one.
Issue 1 - AoA shaders for the Tattoos icons. Loads okay clicking on the Kim icon in the Characters folder, but when you click on the Tattoo icons you get the dreaded black nothing.
Issue 2 - After loading the Tattoo texture maps manually and did a test render got very rough skin for some reason.
Solved this by deleting the Kim figure, than loading Lee 6 from the characters, manually loaded all maps for Kim.
Issue 3 - After loading all the maps manually, noticed a glitch in the render.
https://www.daz3d.com/fw-ja-long-hd-for-lee-6
Issue with the Tattoos
Solved by manually loading the textures. Also the existing shaders for Ja-Long have a Multilpy by colour shader which will need to be copied for the manually added textures.
https://www.daz3d.com/wicked-strappy-swimsuit-for-genesis-3-female-s
https://www.daz3d.com/archery-for-gia
While there is nothing in the product description which tells you which bow and arrow go with the poses - I tried the Ranger Props for Genesis 2 Female(s) but unfortunately was not able to get the poses to work with them.
Substituted a bow & arrow I had in my props library and adjusted the pose to suit. The Quiver prop from the Ranger Props does not suit the poses.
https://www.daz3d.com/ranger-props-for-genesis-2-female-s
yet it is in the ranger bundle
https://www.daz3d.com/ranger-bundle-for-genesis-2-female-s
Which is where I got the Ranger Props from. Poses come with Bow and Arrow presets, but the bow icons look like they are a more modern compound bow.
Echoing others, thanks for taking the time to report on these products, Bunyip!
Ah, the dreaded shoulder crack. Carrara can be fussy about which version of a given generation is loaded. I've had the best luck with the standard Vicky and Mike versions, then turning off the Vicky and Mike morphs, and then activating the morphs desired from other character sets. Usually the crack goes away.
Thanks !!!
Tried M6 with Kim for Lee 6 maps manually loaded - Lee 6 UV mapping out of wack.
Tried Kim preset again - no rough skin this time around.
Tried Kim preset with Tattoo textures manually loaded - no rough skin and no gap - worked this time around !!!
Tried Lee 6 preset with Kim Tattoo textures manually loaded - gap, so using the default Lee 6 instead of the default Kim is the problem.
No idea why I had a rough skin from the Kim preset the first time around - something I loaded must have caused Carrara to chuck a wobbly.
https://www.daz3d.com/vyk-loey-for-genesis-9
Note - Mats need to be saved as a Material Preset in DAZ Studio to use in Carrara.
Expression from https://www.daz3d.com/cdi-magical-jaunt-poses-for-genesis-9
Note - tested the poses in Carrara, they need to be saved as a Pose Preset in DAZ Studio to use in Carrara
https://www.daz3d.com/aspen-for-gia
High Reflection with some of the shaders, manually fixed.
https://www.daz3d.com/vista-dress-textures
https://www.daz3d.com/memories-of-summer-for-genesis-2-female-s
https://www.daz3d.com/ivy-dress-and-shoes-for-genesis-2-female-s-textures
Note - Outfit does not include wings
https://www.daz3d.com/fair-corsair-outfit-for-genesis-2-female-s
